Those round things that you roll on...
By Bi6Dom
#3785979
After going up the west coast and having to do the usual braking hard because a few dozy tourists were hammering it on single track roads or wouldn't pull up into passing places (a few arse chewing the seat moments) upon arrival in Applecross I found my brakes to be somewhat hot and a little smokey, I decided then that it's time to sort these brakes out good and proper. Did a bit of hunting and went for Mtec grooved discs front and back, EBC Red Stuff pads up front and EBC Ultimax at the rear and a lovely set of Goodridge hoses.
Upon strip down of the brakes it became apparent that they were in need of some serious TLC, the rear discs were easy to come off and so the cleaning and preparation began. If you're going to do a job do it right!!! After a thorough clean, wire brushing, and removing built up rust and finally an inspection of the calipers I set about painting them up including the disc cover. Once the rears were all done I started on the fronts and OMG were they bad. The front discs were solid with rust and they had to get hammered off. No wonder they were bad. Anyway getting to the point after 2 days, yes 2 days of working on them removing rust, painting and more waiting for drying time between coats, they are finally done. What a difference, it can stop on a 5p piece now. (Ok slight exaggeration).
N.B When fitting Goodridge hoses to the front, the hose holder has to be adapted by filling the original holder as the Goodridge holder is a larger diameter, also spray plenty of WD40 or similar on joins and connections as mine were well solid and my mate would have had worse problems if I hadn't have soaked them over the day and a half, the rears were a bit of a bitch to do.
By Jimmykey87
#3785998
Looks quality mate. I put the exact same discs on my EP3 last week, still bedding them in but they feel pretty good
By Bi6Dom
#3786032
Jimmykey87 wrote:Looks quality mate. I put the exact same discs on my EP3 last week, still bedding them in but they feel pretty good
I'll get more pics up later, yeah they do look good, they feel 1000 times better, they are so responsive now, when I first drove the car I was braking like I did before and it threw me forward, got me by surprise as to how good they were and the difference. Just goes to show, that your brakes should never be left out a good servicing.
