Upon strip down of the brakes it became apparent that they were in need of some serious TLC, the rear discs were easy to come off and so the cleaning and preparation began. If you're going to do a job do it right!!! After a thorough clean, wire brushing, and removing built up rust and finally an inspection of the calipers I set about painting them up including the disc cover. Once the rears were all done I started on the fronts and OMG were they bad. The front discs were solid with rust and they had to get hammered off. No wonder they were bad. Anyway getting to the point after 2 days, yes 2 days of working on them removing rust, painting and more waiting for drying time between coats, they are finally done. What a difference, it can stop on a 5p piece now. (Ok slight exaggeration).
N.B When fitting Goodridge hoses to the front, the hose holder has to be adapted by filling the original holder as the Goodridge holder is a larger diameter, also spray plenty of WD40 or similar on joins and connections as mine were well solid and my mate would have had worse problems if I hadn't have soaked them over the day and a half, the rears were a bit of a bitch to do.
