Those round things that you roll on...
#3751060
Hey! Quick question, I will be changing my front Pads and Discs for the first time since buying the car at the weekend and wondered if I need to use my Caliper Piston Twisty Tool thingy or if I can just push them straight back? :) Facelift EP3 by the way :)
#3763930
Tomcosmic wrote:
EP3 Ryan wrote:Thanks buddy! May be a Silly question but why is that? What's the difference? (I'm no mechanic) lol
Because the front is just a normal brake piston and the rear has the handbrake mech built into the caliper.
There's a screw thread inside the rear calipers which you unwind when taking the calipers apart for a refurb. If you're just replacing pads then they just need winding. They have a cross section cut out of them which could be used to wind they back with.
