bluntcap wrote:for your "is it wirth it comment" i thought it was just for a random remap when adding a new part, didn't realise you needed to actually buy the KPro 1st. yes KPro is worth it, just ask Stevo M81, recentkly just had his FN2 mapped and he's shocked at the difference it makes to the car's performance and all he has is a better breathing OEM induction DIY jobber.
So true, the difference flashpro has made to my fn2 is amazing makes it fun to drive now. If u do one mod that's worth it i would recommend Hondata as it makes the CTR come alive and lifts the restrictions the Oem map has :bigthumb:
#3543887
This kpro has a base map installed for manifold ect.
Am I right in thinking I can plug this in and it will work straight away
Reduced vtec increase in torque, increased limiter, launch limiter ect all working?
Also everything will be fine/safe to keep like that untill as such a time I'm ready to take to a tuner for a custom map for my car
#3544002
You may need to load the map, I had to do this, but that may be because I had to disengage the immobiliser. Will it be safe......it's not for your car. If it is a map for a mani etc then it'll be usable for your car but as its not been customised for your car no one would be able to give you a right answer. It needs looked at by a tuner to make sure all AFR levels etc are safe.
  • 35
