- Thu Oct 20, 2011 11:34 pm
#3122743
2012:
2013:
2014:
2015:
2016:
Spec Update 12/15*
Cheers to:
Automek
Tdi north
Suspension:
KW Variant 2 Adjustable Coilovers
JDM Rear ARB + Polybushes
JDM Front ARB + Polybushes
Eibach Front Camber Adjusters
Eibach Rear Camber Adjusters
Buddyclub Extended Ball Joints
Automek FRSU
Steering:
DC5 Hydraulic Steering rack conversion (aircon delete)
Tegiwa Steering Rack Raiser
Engine:
K100 Mapped by Russ at Performance HQ (217bhp and 152lbft at the wheels)
Tegiwa Carbon Airbox
Engine mount inserts
Tegiwa Sump Baffle Plates
70mm ported and polished RBC
70 mm Skunk2 black series brass butterfly throttlebody
Exhaust:
Tegiwa 4-2-1 Manifold (Toda replica)
TDi-North custom 2.5" unsilenced B pipe
OEM Backbox
Brakes:
Stoptech 328mm BBK
Stoptech stainless hoses
New OEM Calipers R
New OEM Discs R
Goodrich Stainless Hoses R
Motul RBF 600 Racing Fluid
Tegiwa master cylinder brake stopper
Stoptech blocks of wood (road)
Pagid rs42 blue (track)
Transmission:
Mfactory Helical LSD
New OEM Differential bearings
ACT 225 lb ft Clutch + bearings
ACT Prolite 9 lb Flywheel
Spoon 5.062 Final Drive
Chassis:
Energy Suspension Front Polybush Kit
Tegiwa Subframe Rigid Collar Kit
Powdercoated Subframe
Powdercoated Front Lower Control Arms
Full Underseal
Tyres:
Road: Continental Sport Contact 3
Track: Federal RSR
Cost breakdown
The bill from tdi north for the ecu, mapping, suspension set up, custom exhaust, tegiwa intake, jdm arb, bushes, camber adjusters and bolts was £2477 in 2011
Automek built the transmission for me in 2012 for £400 including: diff + bearings £650 , final drive £410, clutch £250, flywheel 220
Total for 2012 £1920
This year the track wheels and tyres cost me £600 all in
Automek fitted New rear caliper and discs and baffled sump for £350 all in
Automek supplied and fitted all this lot for £490; brakes £1500, £650 on the kw's ,£200 on the buddly clubs and the rack raiser
total for 2013 : £3750
So all in it costs about 8K to build a car to this spec, if you have a good ramp you can save a fair bit on labour! Even so it is very easy to fall off the deep end
2014:
DC5 hydraulic conversion £700
2015:
New Subframe, F LCA's, polybushes, drop links, rigid collar kit £600
I'm well chuffed with the results, the cars handling has been massively improved. It now tracks perfectly straight even when going through standing water on motorways etc. the high speed stability is much improved also with greatly reduced body roll.
The engine is a completely different animal now, it makes as much torque low down as it used to at peak and when it comes on cam the 173ft lb of torque and accompanying sountrack is pretty addictive
. The exhaust is almost as quiet as stock untill 5100 rpm - when it gets throaty
. A special thanks to the guys at TDi - north, the car is old and they had to cut alot of the old parts off. This meant working on the car till midnight to get the job done. Thoroughly professional and nice guys as well - a job well done!
The car is nearly how i want it, a front strut brace and reconditioned brakes will be the next jobs to get done
2013:
2014:
2015:
2016:
Spec Update 12/15*
Cheers to:
Automek
Tdi north
Suspension:
Automek FRSU
Steering:
Engine:
Exhaust:
OEM Backbox
Brakes:
Stoptech 328mm BBK
New OEM Calipers R
New OEM Discs R
Transmission:
Chassis:
Full Underseal
Tyres:
Track: Federal RSR
Cost breakdown
2014:
2015:
