The problem with the goodridge lines is that they are too short, i suppose that is what is happening here with the hel lines pulling through the mount bracket.
I hope these issues can be sorted and that nobody gets hurt due to a failure.
Performancetek wrote:I manufacture, sell and fit around 20 HEL kits per month.Ive never had any come back to use with a failure in the two years Ive been using them.You manufacture HEL?
The cracked outer sheath is not a safety issue, its there purely for Aesthetics. However, we have changed supplier in order to remedy this.
All the bursts weve seen appear to be a result of the hose tugging on the bulkhead connector. This would (should) be noticed upon testing of the lines when fitted, Im sure anyone would agree.
mat wrote:when yours were fitted did you measure them against the OEM lines?
when my mate fitted mine we measured them up and they were about an inch longer than the OEM lines.
mat.
