All info taken from the forum and provided by owners of the system .
Any questions please feel free to ask in here and I'm sure people will answer .
It's so much easier than scattered Gruppe M threads everyday .. Stay on the site longer than a month and you will agree :thumbup:
FAQ
Where do i buy this mofo at the best price ?
Gruppe M can be purchased second hand in the for sale section , or here ...
http://civictype-r.co.uk/forum/viewtopi ... 8&t=126243 EDIT ... Sorry the discount option is no more :bigcry:
Either way these go for around the £700 mark . They hold their value so don't expect any major deals
Is it worth the money ?
That's a matter of opinion , at the end of the day the OEM airbox works fine . If you can spring for an expensive induction kit then by all means do so . It has rave reviews and is proven to be one of the best kits for the EP3 . Obviously there are plenty of other systems to choose from so do your homework .
Is it difficult to fit ?
No , all parts are supplied with the kit to fit straight into your engine bay . Its a simple job and takes 30 min's tops . Most of that is figuring out how to build the Lower case and adaptor
( Other parts are recommended which I've listed further down * )
WARNING
Make sure your scoop clears your bonnet before slamming it down , some scoops STILL foul the bonnet and may need minimal shaving off the edges . It's a £50 mistake so be careful
What do i get ?
Supplied parts in a brand new box
Filter Case
L-Pipe
Cowl Top
Filter
Lower Case
Blowby Hose
Brace 0028
Brace 0323
Double Faced Sticky Tape
V Clamp
Lower Clamp
Nipple
Joint Adaptor
Heat Shield
15mm Spacer
Inlet Air Duct
Clips for cowl top x4
Bolt A x6
Bolt B x1
Nut x2
Wrench ( Allen Key )
Cushion Tape
