Hi guys i don't want to start another debate but :
i have owned both a JDM 98 Spec Integra R and i currently have a JDM EP3.
when you compare an integra to a EUDM civic you ar not making a good comparison in my opinion .... i have driven a number of EUDM civics and i can assure you that the JDM car is noticably different especially since it has an LSD fitted as std.
so we should always compare an integra (both JDM and EUDM, since specs are very similar in this case) and a JDM civic ....
what i can say is that as regards engine and gearbox my past integra (which had an aem cai, full exhaust system, chipped ecu, lightened flywheel and modified 4th and 5th gears) is left behind by my standard civic ... the civic's engine (mine is the 215 ps version) is much stronger from low down and the gearing is phenomenal (mine has also the shorter 4th, 5th and 6th).
What the integra excels is in the handling, driver involvement department ... even though i can attack corners faster in my civic than i did in my teg the car doesn not inspire all the confidence that my teg used to give me .... i really loved that car ... and i wish i would buy one again but ....
why would ask did i sell her ?
simple i had the opportunity to buy a brand new JDM CTR from my local honda dealer and i couldn't resist (my integra was a jap import with over 150k kms on the clock), i couldn't keep the teg as well as i have financial restrictions
