KCHESTER wrote:Right at the end of the production line the cars have a small amount of petrol put in to them. They are started and driven onto a set of rollers like the ones you see when you have your MOT. The headlamps are checked/adjusted at this stage, then the car is revved (not to the red line) and the brakes tested.
The test track is approx 1.6km and used to be the runway for Supermarine Spitfire manufacturing. It consists of some variable textured tarmac a couple of s bends and a big roundabout at the bottom. The cars are warm prior to the test and are not usually cained on the first run, however on the return they are given a good work out through the gears and to the red line.
Someone mentioned the fume extraction on the production line, if i remember correctly they fit an exhaust filter to the pipe which filters particulates etc. if they are to be run for an extended (repair of FQA - Final Quality Analysis) period they have flexible extraction hoses to remove the fumes.
The units will be bench started/tested for approx 90 seconds (Takt) this cannot be construed as running in.
Jamziee, is your friend the engine plant of Assembly Frame manager?
I think it is worth considering that although the engine will free off and turnover more easily once run in, the process of running in is aimed at mating components and ensuring that the honing and grinding remains, this ensures that the oil can adhere to the metal ensuring a layer of oil separates the components. This ensures minimum friction/wear and maximised engine compression. It is not easy to damage the engine but if you run it hard constantly when new it may develop high spots where the metal components become smooth and can't retain the layer of oil essential to reduce friction and prevent seizure.
Speaking to my ex-colleagues at HUM there has been several instances of piston ring failure due to thrashing cold/new engines. You may get away with it you may not! Personally I don’t think it is worth the risk, treat it with respect when new and it will provide you with maximum performance consistently for a long time. It may also use less oil.
Good post.....saved me alot of typing!
As for extraction of fumes, near the end of the AF line, the cars are started for the first time unless there is something written on the VI card(Vehicle identification) stating not to start, there are suction ducts next to the track(line) these help remove the gases whilst ticking over before being driven off the line.The cars then drive across to an inspection pit where final checks underneath are done before passing onto a rolling road.The cars are passed quickly through the gears etc, they are then also checked for headlamp aim , brake test etc.
Basically they are not 'stone cold' when driven up the track.
Years ago i worked in the engine plant were the engines were made and tested 100%, as volumes increased in production, testing of all units was reduced dramatically with only sample testing.I believe our engine build quality was in the region of 99.9% right first time.
BMW 2001 M5 and Yamaha YZF-R1 2002 (inj).
