This is the bulb i got but i just want everything to be sealed tight if that is at all possible
James_N wrote:id love some of these, but id make a right pigs ear fitting them, so can someone recommend me some headlight bulbs? The standard CTR bulbs on dipped beam are pathetic im finding. I need some good bulbs before i end up in a ditch somewhereI used the Osram Silverstars mate
LeeH wrote:Thanks. Im still debating whether to do the HID conversion as i know someone that would do it for me, or just change the bulbsJames_N wrote:id love some of these, but id make a right pigs ear fitting them, so can someone recommend me some headlight bulbs? The standard CTR bulbs on dipped beam are pathetic im finding. I need some good bulbs before i end up in a ditch somewhereI used the Osram Silverstars mate![]()
http://www.powerbulbs.co.uk/
James_N wrote: Thanks. Im still debating whether to do the HID conversion as i know someone that would do it for me, or just change the bulbsAre you a face lift or pre face lift??
and if i went for the bulbs, would i need H1 or H4?
LeeH wrote:LeeH, I also have a bixenon kit which requires some diodes, do you know where I can get these from and which ones please? I'd be grateful if you could let me know as I've been trying to find out which type of diode I need for a long time now. Cheers mateycybman wrote:hi,Not sure TBH Where did you buy it from?? Can you post some instructions up on here??
i have a kit of hid to my ctr 2003 but i cant install it
my diagrams says that with h4 i need to use a relay kit...and diodes....that is normal?? i dont know if the reason is because the kit is Bi Xenon
Regards,
Hugo bejinha
LeeH wrote:http://www.maplin.co.uk/module.aspx?Mod ... ook&U=EcatCheers mate! I've just been looking at your mate's website and came across this photo, would you mind asking him if he knows what spec diode it is please? I think it is the one I need!!!
This may do mate but I'm no electronics expert.
Mylee wrote:6K as Ian recommended. Exactly what I wanted, very white light but with a defined blue tint. These seem super bright after halogens.Mine are the same mate. As long as they kick to the left I think it will be ok.
I'm not sure if it's cos these lights are so much brighter but they seem high towards the left?
Mylee wrote:Cheers Lee, I'll have a look. I've also noticed what looked like a projected shadow on the road, from the car outwards about 10 feet. Again this maybe 'cos the lamps are so bright that I never noticed it before with the halogens.Is your shadow on the left??
Are you anywhere near MOT time yet?
