The Worlds Largest Independent Honda Type-R Club & Forum - "Often imitated, never duplicated"
  • 3gear scratch
  • Those Complete Power Boosting & Drivetrain Mods..
Forum rules:
 #3866271  by CTR2707
 Sun Jul 15, 2018 9:12 pm
Hello,
I have buy Ep3 with 140k miles, the 3gear scratch at hight rpm.
Do i need to change just the synchros or its more than that and it needs a rebuild?
 #3866272  by Lewisgame
 Mon Jul 16, 2018 6:07 am
Check the clutch first. If the biting point is really low then the clutch is faulty and not disengaging correctly.
Also check gear oil. This should be changed regularly and it’s best to use Honda MTF3 on a standard gearbox.
If the clutch is good and fresh gearbox oil hasn’t helped then you’ll need to strip the box to check what you need. Could be just the synchro but it could of also damaged 3rd gear itself if it’s been going on for some time.
 #3866273  by CTR2707
 Mon Jul 16, 2018 7:15 am
I have made my self the oil change from the gearbox and i have used MTF i also put a additive but the scratch still there.
The clutch is hard and really short but they tell me it is a Pedals and thats normal..
Do you know the costs if it is more then the synchros?
 #3866276  by Lewisgame
 Tue Jul 17, 2018 6:42 pm
Clutch shouldn’t be hard and short which says to me your clutch isn’t disengaging correctly causing the issue.
It’s not going to be a cheap repair. A clutch change alone ranges from £300-400. Add in repair to the gearbox you’ll be well over £500
 #3866282  by CTR2707
 Sat Jul 21, 2018 7:05 am
Ok i will try the clutch first, thank you!;)
Recent Topics
User avatar Brake Pads
by cory_veloce
Fri Sep 20, 2019 1:11 am
User avatar ABS and Battery Light on - EP3 2004?
by mat_555
Tue Sep 10, 2019 9:40 pm
User avatar FN2 alternator
by 15repyt
Tue Sep 10, 2019 8:11 pm
User avatar Lewisgame's Cosmic EP3
by Lewisgame
Thu Sep 05, 2019 6:52 pm
User avatar Honda Civic Error Code P0780 etc
by r.kelly
Sat Aug 17, 2019 4:44 pm
Twitter
About Us
CTRO™ was the worlds first and largest Civic Type R club and forum. Established in 2002 it brings together people from all over the world to discuss their one love of Type R's. Now fully updated for 2015 the new forum based on BBOOTS PhpBB® Unofficial HTML5/CSS3 Theme. It’s Clean And Crisp Design Looks AWESOME Across All Browsers And Devices.
Don't forget to check out our huge Facebook group and Twitter Pages for all the most upto date goings on in the world of Honda and the Type R Brand.
CTRO
Established : 2002
