- Sat Mar 04, 2017 9:58 pm
#3863195
Hi guys,
I trust you're all well
I disconnected the car batter for 2 hours 3 weeks ago and since my car alarm has been going off intermittently ever since. The weirdest thing is that even my key fob doesn't work for the first 30 odd clicks initially, but when it finally does work then it works consistently for a few hours. But the following day same problem.
I have gone through and searched everything on the forum but not quite came across the same fault? I've tried removing the battery and tried the car in ignition 2 clicks method but nothing.
Could it just be I need to reprogram my key? It's the most bizzar fault and perhaps easily the most annoying when the car alarm goes off at silly o'clock
Any help would be greatly appreciated
Regards
Sent from my SM-G850F using Tapatalk
Regards
