Let it breathe...
By Jimmykey87
#3785272
Hi
Whats the easiest way to remove an AEM cold air induction kit? Is it bumper off / battery out / out through the nearside wheel arch?
Once its done it will be up for sale :wink:
By Jimmykey87
#3785278
noooooobs-type r wrote:Just take the wheel off and pull back the arch liner thats all the space you need.
Cool cheers, sounds easy enough then [smilie=karls_thumb.gif]
By noooooobs-type r
#3785279
Yeh its pretty simple mate, just try not to fudge the plastic clips that hold the arch on as you want to put them back on after and for them to hold properly. Loosen the filter and remove it first then pull the piping up from above.
By Jimmykey87
#3785282
noooooobs-type r wrote:Yeh its pretty simple mate, just try not to fudge the plastic clips that hold the arch on as you want to put them back on after and for them to hold properly. Loosen the filter and remove it first then pull the piping up from above.
Cheers mate.
