By Ben_ep33
#3770916
Looking at getting some sa3r advans in the next couple of days to my ep3 typer prefacelift see a few doted on ep3s here and there I'm running standard height ATM but that's soon going to change so need to know tyres sizes and possible spacing thanks :)
Wheels specs are : ADVAN RACING sa3r
Fronts 17" 8J offset : 35
Rears 17" 9J offset : 38
By WizardinBlack
#3775348
When adds was going to sell me his sa3rs he sent me this message about his fitment.
They came with conti 3's on the 8j et32 (fronts) and potenzas on the 9j et42. All 205/45/17 they are all 5x114.
At first I had the 9j up front. That works fine with those tires, I experienced a tiny noise on full lock at low speed sometimes (say doing a u turn) which was just the tire slightly touching the plastic guard at the front (not the arch) but that was when I was running very very low... So you probably wouldn't experience this if your car isn't dropped a load.. (No biggy anyway)
I then ran the 9j on back with a 20mm spacer unrolled rear arches and it caught a bit going fast round bumpy bends... Again because it was very low.
I used rear spacers as the 9j slightly touched the rear arm ... I think a 10-15 mm spacer would of been perfect and allowed me to use better size tires...
I then ran 20mm spacers on front and 25mm in back and rolled the rear arches and it never rubbed...
To sum up, with a fast road setup you could fit wider tires... I would run the 9j on back with a small spacer unless you have pulled front arches/ j's wings..
Anything else let me know
