HyacinthBucket wrote:If you need convining taz, read here:
http://forum.hondarevolutions.com/viewt ... sc&start=0
I'm sure you would have read it already though?
Yes i had read that thread, but the first entry, clarifies my statement.
"Just for those that may be interested .
We have a lot of talk about CAI's and whether they make any difference etc....
Well I eventually got the intake done on the ITR yesterday .
The filter had been sitting in the enigne bay on a longish intake pipe.
It's now in the inner wing .
I'm not going to say whether I felt any benefits or not. That would be purely subjective opinion.
But here are some facts.
The intake air temperature used to read 34 degrees under normal use.
Rising to 38 degrees when stationary.
Since putting it in cold air the temp when stationary is still about 38 degrees. (the temp sensor is at the throttle body I believe).
But within 300 yrds of moving, it falls to about 24 degrees.
Normal running temperature is now approx 20 degrees .
This is without any air feed to the filter .
I think there is a formula for calculating gains in respect of intake temperature if anyone knows it . (although I doubt it would be too accurate)"
If i am reading it right, he relocated the filter away from, the main heat area, to the wing, cooler area and the temp drop when moving was down 4 degrees. Now with the added induction of cold air, which is very easy, this will drop further still.
The main point is how much cooler the air is, when the car really needs it..ie when moving, with ram air feed this should not cause a problem.
SIGNATURE PICTURE REMOVED BY MODS. TEXT ONLY PLEASE.
