Go go juice and lubrication.
#2240638
yo guys,
are any of you guys using ELF oil?,
my car is in honda on friday for a oil change,i spoke to maz at hond-r and bascly im using the wrong oil castrol edge 0w-40 with my car having 42k on it,he said to use magnetec 10w-40,????
but the honda dealer use Elf oil,
i have bought a HAMP oil filter so im stuck with witch one to use,
opinions welcom.....help
lol
james
#2368751
OIL MAN i need your help again, i have been told that Fuchs are stopping there sypersyn 0W-30 that i was using which you said was very good a fine in my type r. just poped to see my dude who gets me the good deal on Fuchs and there are now selling Fuchs Titan GT1 5w-40 fully synthetic, im having my service done on friday, is this oil as good as the one before and up to standard.
and secondly can you mix a Fuches Titan GT1 5w-30 oil with Fuches Titan GT1 5w-40 oil thats the same,
Thanks Richard
#2389146
Wizza wrote:Hi Oilman
Wonder if you can help, what is the best oil to use on a 2005 CTR with 60K
Still Silkolene Pro S 5w 40 ??? or do you recommend a better one if such a thingout there
Thanks in advance
Wizza
That's still what I'd go with. Top quality stuff
#2397699
Being honest with you, I'm not good with some engine model numbers. The K20 is in the current and previous generation of Civics isn't it? The current Civics like a 0w-30, the previous ones want a 5w-40. For the best 0w-30, go for the Gulf Competition
http://www.opieoils.co.uk/p-60121-gulf- ... -0w30.aspx
It's not so easy to say what the best 5w-40 is as there are a lot more of them. Silkolene Pro S, Gulf Competition, Millers CFS, Redline and Motul 300V are absolute top end oils, as good as or better than anything else on the markets at the moment.
http://www.opieoils.co.uk/c-656-5w-40.aspx
Tim
#2402249
The Royal Purple test that most people see is a very biased one, using equipment that has no relation to the workings of engine (minimal heat, no combustion). Here are some comments from a leading oil chemist on the Falex test the magazine test (sponsored by Royal Purple if I remember correctly) uses.
http://docs.google.com/View?id=dfjpbcch_0cd3v2hgb
As you can see, if you want to go with the results of that magazine test, you're best off popping down to Tesco and picking up a 12 pack of lager. As you can see via the link, an engine is the best place to test oils. Our sponsored drivers do that for us. They probably test the oil a whole lot harder than anyone else, and their engines seem to remain in better condition than they should. They use good oils, the Silkolene Pro S and R and Motul 300V generally and none of them have even asked us to get hold of Royal Purple.
Tim
  • 9
  • 10
  • 11
  • 12
  • 13
  • 22
