Yes was told it would be ok........Not my fault.Erm when you did the 1/4 Mile run did you attempt to burn your tyres out at all ? If so how did you do it, and do you know how to do it properly ?
Only thing I can do is get it sorted now........Not happy but what can you do.
Also did you slip the clutch on the start or just drop it.
There no way it should have gone with only a few runs down the 1/4 Mile the standard clutch aint that bad
Would get a LSD though, deffinately worth it.
So Does John Force
