Let it breathe...
#1855498
david_s_fox wrote:Is the Gruppe M generic across the CTR range - ie FN2 and FD2?
Thanks.
this model no - but they've development similar models to fit the fn2 - not sure about the fd2 yet, unit-8 iss selling them i think :wink:
also ive got my gruppe m installed, couple of problems.
1. the rubber seal around m lip keeps coming off - any suggestions to make it stay on there better,
2. also ive attached my m with the bracket and bent it to shape so it stays in place at the pipe connection. Anyway to stop the head moving as much.(suggested bracket)
see pic
#1855710
MugenSeiki wrote:
Devilfox wrote:
david_s_fox wrote: 1. the rubber seal around m lip keeps coming off - any suggestions to make it stay on there better,
Superglue mate
so simple :bad-words: - wish i was as smart as you :sad: - any suggestions on the bracket?
#1855979
Thanks Devilfox, just compiling a list of potential parts for the FN2 or FD2! Had a Gruppe M on my DC5, never fitted very well on that, and the rubber seal on mine was loose as well! To be honest, as MugenSeiki wrote, superglue is a viable option, or some similar adhesive. There not the best fitting kit as I recall, but an incredible sound, so it was worth it for the VTEC howl!
#1944557
i read the appropriate link in mugenlad's first post, but still kinda non the wiser.....
every time i open my bonnet now after driving, my gruppeM is sitting like this (see pic below)
am i supposed to double side the top of the air box to the scuttle, it never mentioned it in the instructions?
#1944689
no its not forcing it as such, however when the airbox is placed where it should be the bolt from the bracket/heatshield rubs against the airbox. Therefore i had to cover the bolt with abit of the supplied sponge tape, and put abit on the air box also, to try and save it from abit of damage.
#1944707
Mr Max wrote:no its not forcing it as such, however when the airbox is placed where it should be the bolt from the bracket/heatshield rubs against the airbox. Therefore i had to cover the bolt with abit of the supplied sponge tape, and put abit on the air box also, to try and save it from abit of damage.
i had to mod the bracket to fit mine, just bend it into the correct position with a vice :-D , mine fits perfect (after a tiny mod) :wink:
its not forcing, imo its when you give it some and the engine jumps back and forth allowing the gruppe m to slide out of the scuttle position!
#1946174
tightened the connections as mugenseiki suggested, but also doublesided taped the top of the airbox to the scuttle withsome d'sided tape i had here. seems to have done the trick. also bend the heatshield/bracket away from the airbox, so all's good again :cool:
#1946218
Mr Max wrote:tightened the connections as mugenseiki suggested, but also doublesided taped the top of the airbox to the scuttle withsome d'sided tape i had here. seems to have done the trick. also bend the heatshield/bracket away from the airbox, so all's good again :cool:
looking forward to fitting mine........all these technical fixes i'll have to remember! :lol:
#1946233
still not fitted yours, youve had it for a week or two have you not?
#1946246
nah prob a month........ :oops:
-bought a new scuttle from dealer........(wanna keep mine) need to get that sent off for modding
-Want/Need induction hose
Then the phone call to insurer...... :roll:
#1980034
out of interest does anyone know the sequence for delivery when tracking it through the EMS site? At the moment mine is:
Aug 27
2:44 Dispatch from outward office of exchange TOKYO INTERNATIONAL Branch Tokyo metropolis
138-8799
Dont know how many more steps there are.... im so impatient!
