Danith wrote:I'm in exact same boat. The pedal in my Ep now feels light as a feather in comparison to my recently acquired Fn2! The FN is on 76k now.
Had the clutch bled, braided line (just cos why not), pedal has been adjusted and the bite pt is a bit better but the pedal is still really stiff and gearchange feels pretty laboured (but not crunches or slipping). Read up that it's most likely a worn pressure plate spring/mechanism?
Looking likely that I'll get it changed anyway. Been quoted between 300-380 so far. YAY!
Hi,
I just bought a 2008 Type R FN2 model, with only 46K, and I have the same issue !! Bit point is on the floor, clutch is so stiff, really seems to be a mechanism issue. I have checked the fluid level and colour, it is all perfect !
I am a bit disapointed with such low mileage to have such an issue...
So do I then have to change the clutch ?
If so, what is the best "fast road" clutch to buy ? I'm not really into OEM as it could lead to same issue, but more in aftermarket one. What is best option : Exedy ? Exedy Stage 1 (a bit more resistant) ? But I had a new Exedy on previous car and they were known to be noisy (and I had the issue !), so I'm not really confident any more with the clutchs world !!!!!!!
Thanks for your feedback
