Down A Bit, Down A Bit, That's It...
#3865667
We have been working on an "affordable" track focused setup for the EP3 platform, and it is here... MeisterR ClubRace Coilovers.
This is our first production batch so I want to get some opinion on what members think and if it is something you want MeisterR to continue offering.
ClubRace Springs Rate:
Front: 9kg/mm
Rear: 16kg/mm
Dampers are adjustable mono-tube damper with valving paired to the springs rate.
Critical damping is right at the top and most driver will be within the top 5 clicks on track.
The front upper hub hole also have been elongated to enable over 3 degrees of negative camber.
These are design for performance using high grip tires such as Toyo R888 / Advan A048 / etc.
Let me know what you think, let me know any questions you may have.
I want to hear what the community think on "budget friendly" track setup such as the ClubRace.
Jerrick
