Update:
Turbo time !
Finally in a position to do a turbo conversion on the car!
Aims are to get the running around 380hp with a boost by gear setup. It is still going to be my daily and i dont want the car to be something that just spins its wheels up all day, hoping the bbg and quality tyres will help with that.
I would guess max boost will be maybe 10psi, Romain will be mapping it when its ready and im sure he will know whats best whatever it will be.
This is pretty much going to be a full diy turbo conversion. Good friend of mine is a fabricator of aircraft bits and is going to help make a manifold and down-pipe and weld all other miscellaneous bits that will be required
Using a Full race manifold we made a jig and so ours will be based off that.
Parts list
So far have attained
Garrett GT3076r .82ar
ID1000 injectors with pnp clips
Competition Stage 4 clutch kit
Turbosmart Hypergate 45mm WG
Turbosmart Race port 50mm BOV
Intercooler and Pipe kit
Walbro 255lph fuel pump
Speed factory 4 Bar map sensor
Torques teflon hoses for oil & fuel lines
Miscellaneous fittings
Need to buy a load more miscellaneous bits and fittings etc
Full race manifold jig
Garrett GT3076r
Turbosmart wastegate
Really nice quality on these
5 psi Spring fitted
Turbosmart Race Port BOV
4 Bar MAP sensor
Torques lines and fittings (few missing)
Around £150 for all the plumbing bits
Clutch
Intercooler
Regret the size of this slightly as fitting it behind the bumper will require lots of trimming. If your looking to get one for your project would definitely recommend going something smaller than 3” thick and shorter in length.
New shoes.....wider and a low offset. (will have a 23mm poke to standard)
Rota force 17x8 et35
Yokohama AD08R
