- Thu Nov 03, 2016 8:31 pm
#3861187
Eml has been flickering but now stays on . Car drives fine.so plugged up the reader and fault code 0325 knock sensor comes up so I cleared the fault and eml stays off until you go over 3k then comes back on and stays on. If I change the knock sensor will that cure it or could it be something else . Any help appreciated, thanks. Car is ep3.
