By Collister
#3847057
Well guys I picked up my 3rd type r up a JRSC EP3 about a month ago so thought it was about time I started a thread.
I have done a few bits to it since it was purchased but have some big plans ahead.
Current spec
Engine
Jackson Racing supercharger 8psi
650cc RC injectors
Hondata K100 ecu
Gruppe M airbox
Dc sports manifold
Supersprint b pipe
Area motorsports thermostatic oil cooler
Clockwise baffled sump
Energy engine mounts
Transmission
Quaife atb lsd
Powerflex gearbox bush
Tegiwa short shifter (to be fitted)
Tegiwa solid shifter bushes (to be fitted)
Facelift flywheel
Suspension
Hsd monotube coilovers
Adjustable camber bolts
Adjustable camber arms
JDM front anti roll bar
Skunk2 rear trailing arms (to be fitted)
Asr subframe brace (to be fitted)
Beaks lower brace (to be fitted)
Wheels
Rota boost 7.5x17
Brakes
Goodridge braided hoses
Ferrodo ds2500 pads
Interior
Leather type r seats
Recaro SPG seats to be fitted.
Now some pics
Waiting for the ferry back to the Isle of Man after a long two days driving from heysham to Essex and back to Liverpool, trusty sprinter in the back ground
Back home parked next to my parents EP3
Gave the engine back a quick clean up
Washed and polished
Yesterday treated it to some new rear brakes and power flex gearbox mount, had to change the exhaust over for the Manx registration test.
swapped it over to the oem wheels as the tyres were almost next, also sorted the squeeky front brakes.
Sitting pretty low on the front :-)
By Stamford78
#3847081
Very nice. Can you tell me what was causing the front brakes to squeak as mine has just started doing it. Congratulations on the car.
By Collister
#3847088
Stamford78 wrote:Very nice. Can you tell me what was causing the front brakes to squeak as mine has just started doing it. Congratulations on the car.
they were binding slightly also. the pads just needed some copper slip on the back
By 160mph_boy
#3847098
What power is it currently putting out... any dyno print outs?
Engine spec sounds good 8-)
By Stamford78
#3847104
Ok thanks. Will give that a go. Merry xmas.
By Collister
#3847120
160mph_boy wrote:What power is it currently putting out... any dyno print outs?
Cheers Its 298 Bhp I'll get a pic of the graph up soon
By Collister
#3847298
So good week this week it passed the our import test first time so just need to re register it now.
Small update fitted my Tegiwa short shifter and solid shifter bushes
started stripping the old bushes out
old bushes out
Short shifter and sold bushes
New bushes fitted
Short shifter fitted
Hey presto done
old bushes pulled out
New shiney ones
Almost done
All back together
Ordered one of these last week also couldn't resist
By w6ady
#3847300
I use one of those shift lights pal good bit of kit. Very bright for day time which is ideal also auto dims at night. Stops you hitting the limiter so much so should help engine life. I found it a bit awkward to set up but that's probably me being a plank :lol:
By Collister
#3847314
w6ady wrote:I use one of those shift lights pal good bit of kit. Very bright for day time which is ideal also auto dims at night. Stops you hitting the limiter so much so should help engine life. I found it a bit awkward to set up but that's probably me being a plank :lol:
Nice should be good, did it come with all the connectors etc? Easy enough to fit?
By w6ady
#3847315
Not sure on the fitting mate as area motorsport fitted mine for me. Sorry I can't be anymore help. I downloaded the operating manual from the Internet to help me set it up. I found it a bit awkward but got there in the end.
By Collister
#3847376
w6ady wrote:Not sure on the fitting mate as area motorsport fitted mine for me. Sorry I can't be anymore help. I downloaded the operating manual from the Internet to help me set it up. I found it a bit awkward but got there in the end.
Ok cheers I'll see what it looks like when it comes then I will decide if I can be bothered fitting it :LOL:
By Collister
#3847519
This weekend job lined up, I just need to workout which cable is feeding the Rev counter
By Collister
#3847595
Well decided to fit my shift lights this morning could have ended in catastrophy due to messing with wiring never being my forte some pics
Dial custer housing removed
Dial cluster and centre console taken out
Shift light sat in postion with the cables routed
Wired up
Started setting them up
All done just need to test them later
By Collister
#3848805
Small update but not though show yet.... I've sorted my the roll cage Ive booked for the car to go to Sw Motorsports for custom cages multipoint cage with welded in seat rails. Whilst it's there they are doing removing the abs using 40/40 prop valve with bias adjuster and hydro handbrake, aswell as flocking the dash.
By Collister
#3848812
Cosmic-Dan wrote:Nice update, will be following this. Are you looking to go racing?
Cheers, I'm planning on doing my local hill climbs and trackdays for now then see what happens :-D
By Collister
#3849330
Parts collecting at the moment
Some 6pt harnesses
I stripped the rear this afternoon so I will get some pics up later
By Collister
#3849543
Well I've took a turn on this. I seem another ep3 local to me it's an 04 facelift with less miles. The plan is to swap the jrsc and the other mods to my new car.
excuse the poor pics will get some better ones tomorrow
By Collister
#3849628
MichaelEp3 wrote:I do prefer the facelift (as I have one) but your leaving the best colour behind also :P
good luck with the swap !
I don't really mind I like both, the facelift means I can run an undertray splitter. I do like the red though
Added in 2 hours 23 minutes 7 seconds:
Some better pics of the new car
Added in 23 seconds:
