doug2507 wrote:Nice one Lewis, let us know how she drives!
godfridge wrote:Yeah how does it feel compared to your old setup?
Well I went to Goodwood Festival of Speed on Sunday so it was a good chance to give it a run.
Compared to before, the power delivery is far smoother. Vtec at around 4,000rpm (about the same as last time) comes in real smooth with just the engine note changing and the power starts to pick up, then at around 5,000rpm it really starts getting a move on. In the graph there's a slight drop in torque between 4-5k so that's what I'm feeling. Then it just keeps pulling all the way to the redline whereas before at 8,000rpm you could feel the car starting to hold back. It burbles and pops a little more on the over run which sounds nice.
In other news. These have finally turned up!
They don't look a great deal different from the Zeta-R. From the looks of it they use the same body and top mounts ect but there's numbers scribed on the bottom of the shocks along with an Allen key bolt poking out. I've already dismantled the rears for a lick of grease on the threads to prevent seizing. The covers are a nice touch and should help keeping them clean and lasting longer. From memory the bump stops are a different design and the seal looks different as well. Should get these on at the weekend and put to the test in a few weeks at Silverstone.
