Not much going down recently. Noticed over the last week or 2 that I've been getting soot deposits on the rear bumper. Followed by an intermittent engine management light. Turned out to be the lambda on its way out. After fitting I did notice it was slightly crisper on part throttle.
As for the cam situation...
I got them pretty cheap. TDI North tested these on a DC5 (these are the exact cams used) and over majority of the rev range the produce the same or 1-2bhp less until past 8k where they make a little more power (comparing to the JDM cams). EP3 engine is slightly different so would be interesting to see how they perform. Either way they're a good upgrade over the OEM cams.
Reason I didn't go nuts with stage 2's is I'm a little undecided what I'm going to do with the car at the end of the year. My heart wants an E46 M3 and make it a pure track weapon. But that's an expensive route and would put my house buying fund on hold. Don't think I'm prepared to do that.
In talks with Meister R about their GT1 coilovers I'm keen in. So the current set up could be up for grabs!
