you can temporarily fix it by pushing the parts of the dash you suspect of involvement - this is only good for between 2 - 4 seconds (summertime test only)
i'm not sure if it's the housing to the air con fans, the fairly flat bit on top in the middle of the console or the cowling behind and enshrouding the dials
anyway, it's annoying
more than that, i've also got something that sounds a bit like a buzz from the door speaker on the passenger side, but once i took everything out of the passenger door pocket it stopped, any ideas?
