- Thu Apr 07, 2011 9:55 pm
#2932013
I fitted my Mocal/Setrab oil cooler. This took weeeeeeeeeeks!!! :bad-words: I got the kit from a tuning company on Ebay. It came with a Mocal thermostatic plate, braided hoses, a 25 row Setrab rad and all the fixings and brackets needed.
Its a good bit of kit, and half what some tuning companies are charging for the same kit.
I didn't want to run 2 sandwich plates, so i removed the Defi plate. This meant i had to find other take off's for the sensors, which caused a total baw ache!!
I started with the plan to tee off the oil pressure switch like this.....
I had to drill out the cross slightly for the fat temp sensor to fit down, only to find i couldn't turn the cross into the block as it fouled something. Grrrrrr!! :bad-words:
So drunk 1 night lying under it i had a brain wave...... How handy would it be to take the temp sensor off the sump plug!!!
Then i could use this wee chappy (Left of the pic below) which i discovered, and it just about worked, but it was too fat and pushed the braided oil lines onto the red hot exhaust manifold.
I also found a company who made a tapped sump plug..... but it was made of brass......
(Its all i could find)
It looked like this......
Then i discovered the pressure adaptor was too fat, and when i lightly tightened the sump plug it snapped...... in the sump!!! :bad-words:
I was raging!!! I spent the next half hour digging it out with a screwdriver chapped in it. So wasted a week waiting on useless parts!!
Undeterred, i found a company that done them in stainless steel. What a bit of machining it was aswell.
I then ordered a remote pressure kit which was a lot thinner than the adaptor i found, but done the same job. This all taking about a week delivery each item i ordered. So the car had now been sitting in the garage on axle stands for about 3 weeks!!
Soooooooooo, i finally got it fitted and everything back together. Now it looks like this.......
