So really all i want to know is, is this something to be bothered about or should i just ignore it? I got the car booked in at TDi north next month for its 84k service so will mention to them aswell.
Any advice would be great. thanks,
Mark
Sam_EP3 wrote:I have exactly the same thing, metalic rattle noise starts about 5 secs after first starting the car from cold and seams to dissapear as the car reaches operating temp, runs perfectly fine after that. Asked a Honda technician if he had any ideas or encountered the same problem, just told me to do an oil change, did the change and noise still there! Friend of mine whos a mechanic thinks it may be a chain tensioner problem, which has got me paranoid about it the chain jumping a tooth an ruining the valves!
Mart wrote:Sound like Chewbacca by any chance? It should and lots of cars had/have it.Its a kind of tinny. Metalic sound as the rollers and belt move round. Seems to go after a few mins when the car reaches op temp. Read about that chewbacca noise before and dont think its that.
I was quoted £190 odd to fix it. It's just a slightly annoying noise, nothing is being damaged.
Shik wrote:Interesting. I think I have a similar problem, dont have a clue where it is coming from though which is well annoying bacause I dont want to get mugged off by Honda in a couple of weeks when I send it in for a service. It is only there when cold, sometimes makes quite a loud sound for a second or so when I start it (espcially in cold weather) and then when I let go of the accelerator it sounds like something is unwinding as per the engine revs slowing down.
Its been happening since iv had the car- when I test drove it the engine was warm so it didnt make the sound. Does my problem sound similar to anyone elses? Cheers.
Shik wrote:It is only there when cold, sometimes makes quite a loud sound for a second or so when I start it (espcially in cold weather) and then when I let go of the accelerator it sounds like something is unwinding as per the engine revs slowing down.I have exactly same... plus the short *beep* sound too.
