Right , ive read the thread and reckon its pretty straight forward in my situation ...
oilman wrote:sp00d wrote:My dealer stuck in shell fully synth 10W-40 on my first service. Is it worth bleeding the whole thing dry and sticking in mobil 5w-40? Or shall i just top up with mobil 5w-40?
Ok,
The Shell fully syn is not a synthetic, it is a hydrocracked mineral oil, my suggestion is to top up with something similar, and save the good stuff for the next oil change and start with a clean slate, not point mixing the good stuff with the ok stuff.
Guy.
I kinda figured that from this post , just double checking its that straight forward .
just got the car , its got 300 miles on it . Im assuming Honda have put in the 10w-40 youve mensioned , to run it in .
1st service is in March , and ill keep using that stuff till then .
When its service time , ill buy your stuff off you ( silkolene 5w-40 ) . Get an oil change , and use that stuff till the car dies
Have i got it right mate ?
and how much do i need for an oil change ? Honda will be doing it obviously but how much do i need to buy off you ?
