By wheelconnector
#1925904
Hey,
I'm going to be placing an order on an FN2 tomorrow or the day after, and I was just wondering what types of modifications were out there for this car. I also think that it would be a good idea to have this be a constantly updated sticky. So yeah, any aftermarket products you know of that apply to the FN2, please post them, and I shall update my post to list them. I think this would help a lot of the newbies (such as myself) that come to this forum.
MODS (items listed are in no particular order):
Air Induction:
Unless combined with a remapped ECU, air intakes will not make any significant gains on the k20z4. http://www.hondatech.com.au/forum/showthread.php?t=2378 scroll down for more info on this.
1. AEM - Said to suffer from heat soak. - £132.77
2. Injen Cold Air Intake - video/sound clip.
3. ABP Powertek Stainless Steel - Said to suffer from bad heat soak.
4. Toda Sports injection kits - £1,665.00 - £1,971.00 http://www.toda-europe.com/catalog/inde ... th=180_253
5. JDM FD2R RRC Intake Manifold - Said to be a tight fit, but it does fit.
6. Spoon 70mm Venturi throttle body - Said to be a tight fit, but it does fit.
7. HKS induction kits - Available from TDi-North:
- Premium Suction kit. £165.00 + VAT - Intake using the standard airbox
- Racing Suction kit. £225.00 + VAT - Conventional HKS open cone intake
- Super Hybrid replacement filter kit. £26.00 + VAT - Drop-in filters for standard intake
8. Culasse's short ram intake - The modified mass airflow sensor tube gives correct air/fuel readings while eliminating the shortcomings of a CAI. http://www.civictype-r.co.uk/forum/view ... 7&t=167719 - 300EUR
9. PIPERCROSS Air filter induction kit (inc heat shield) £129.50 inc vat
10. POWERTEC Air filter induction kit (including heat shield) £70.00 revolution247.com - Filter seems too big for the provided heatshield, meaning the filter will sit diagonally. Also, the MAF tube is made of metal which can't be good for heatsoak.
11. Team Dynamics induction kit - £450
12. ITG Maxogen air induction kit
13. Gruppe-M induction kit - The most sought after kit for the FN2. Their dyno shows an 11hp gain. This will not fit left-hand-drive cars as the brake master cylinder is in the way. GruppeM has said that the development of the LHD version is a bit behind schedule, but should be released in about a month (updated 28NOV). RHD version is available now - approx. £575
14. K&N APOLLO closed air intake kit now available. Said to give 6-9bhp - £159 inc vat. (from ABP)
15. BMC replacement sports air filter element - Designed to replace the original paper filter in the standard airbox this cotton gauze sports filter will never need changing and should improve throttle response along with a slight increase on power (approx 2bhp) - £43.50 inc vat (from ABP)
16. Driven Crazy Performance Management Scoop'in - Cold air inlet duct.
17. Driven Crazy Performance Management Air Intake System - When combined with the Scoop'in inlet duct, this system supposedly gives approx. 12bhp. - Scoop + intake = approx. US$550 (from Joel Cheong [joel@driven.com.sg])
18. JAS Motorsport induction kit:
- AIRBOX Top 558,00€ - reference: CCR-6004C-2
- AIRBOX Bottom 467,00€ - reference: CCR-6004C-1
- INLET DUCT ON BUMPER 250,00€ - reference: CCR-6004C-3
19. K&N Sports Air Filter Replacement Elements - £42.50 (from ABP)
Exhaust:
1. Milltek - Sounds beautiful, but power gains are almost non-existant until 7,500rpms, where a few HP are gained, but only a few. - £495 inc vat with discreet tail pipes, £545.00 inc vat with 3" round tailpipes
2. HKS full exhaust systems - £650-700
3. Blueflame Performance exhaust system
4. JTune catback exhaust system - In development. Should be released within the next three months (updated 05SEP) - £727 + shipping
5. Team Dynamics Stainless steel exhaust system - Full system available, manifold (+ de-cat or Sports cat), and a cat back system, all interchangeable. Mounts on existing road car mounts. Power increase not yet confirmed.
- Cat back exhaust system - £950
- Sports cat - £500
- Track day de-cat - £250
- Exhaust Manifold - £950
6. CPL exhaust manifold - Gives about 12-15whp, and increases torque dramatically - £749 plus vat, fitting £67.23 plus vat.
7. Gruppe M Exhaust system - In development.
8. Supersprint Exhaust System - Measured with 7bhp gains. Will be released towards the end of 2008 or beginning of 2009.
9. Invidia catback system - £538 available at CPL Racing
10. JAS Motorsport Upgraded exhaust pipeline Group N - €2,500.00
11. Toda Exhaust Manifold - This does not have a catalytic converter. - £839.273
12. Toda Exhaust system - Comes with an optional red triangle exhaust cutout. - £795.101
13. Martelius racing exhaust - Single exhaust system designed for Group N rally use only.
- Modification to the front exhaust, original part needed for platform. Product code 180034 - €120
- Midpipe, no silencers. Product code 180035 - €136
- Rear exhaust without catalytic converter, product code 180036 - €410
- Alternative to the previous: Rear exhaust with FIA homologated converter, code 180036K - €960
14. XO Power Tuning Race Header - construction of header: full 304 stainless steel, cnc machined flanges, comes with 2 on sensor sim included for non kpro users, fully mandarel bent runners with tig welded joints, 3 piece design system 1 hour min installation time. - Titanium model to follow in 3 weeks (updated 26NOV). - £625
15. Scorpion Exhausts / Revolution Motorstore - £479.00 including VAT
Suspension:
1. Eibach progressive spring kit - £151.29
2. Front camber bolts - £13.00
3. Fast road geometry set-up - Adjusting camber, caster, and toe.
4. HKS Hypermax III Sport damper kit - £1,285.00
5. OMP Front & rear strut tower braces - £78.72 & £58.75, respectively.
6. Rear camber/toe shims £6.00 each
7. KW Variant 1 Coil-over suspension kit (pre-set dampers, adjustable height) - £580.00 inc vat (ABP Motorsports)
8. KW Variant 2 Coil-over suspension kit (adjustable rebound dampers, adjustable height) - £769.00 inc vat (ABP Motorsports)
9. KW Variant 3 Coil-over suspension kit (seperately adjustable bump & rebound dampers, adjustable height) - £949.00 inc vat (ABP Motorsports)
10. ABP -30mm Sports lowering spring kit £150.00 inc vat
11. Team Dynamics spring and damper upgrade - Ohlins fully adjustable – price & availability dependant in interest in this product. - £1.700,00
12. Toda Fightex Type DA fully adjustable coilovers - Front:10k - Rear:8k - Hand Built and Custom made to order - £1,978.92
13. D2 Racing Coilovers - Fully adjustable (36-way dampening(51mm shocks), and ride height) - 999.00EUR (from 12tune.nl)
14. Eibach exclusive ABP specs - 30mm lowering springs designed by Eibach as per ABP Motorsports' specifications. - £149.50 including VAT (from ABP Motorsports)
Engine internals:
1. Toda High power connecting rods - http://www.toda-europe.com/catalog/inde ... 80_252_254 - £1,180.00
2. Toda High compression piston kits - 12.1:1 £695.00, 12.2:1 £770.00, 12.3:1 - £770.00.
3. Toda N1 high compression piston kit (13.6:1)
4. Toda 2150cc stroker kits - £2,305.00 - £2,690.00
5. JTune Extreme kit - In development.
6. JTune Ultimate NA kit - In development.
7. Hondata heat-shield gasket - £50.22
8. Spoon magnetic sump plugs - £24.10
Forced Induction:
1. JTune Supercharger kit - In development.
2. JTune Extreme Supercharger kit. - In development.
3. CPL Supercharger Kit - Produces 291hp at the wheels with CPL's exhaust manifold. The kit includes the supercharger, manifold, injectors, clips, Hondata replacement ECU, 8psi pulley, belt and ancilliaries. You will need a different air intake for the supercharger kit, you can either fabricate one yourself or alternatively CPL will have these available in a few weeks time. Price includes fitting/install - £3126 including VAT.
ECU/Electrical:
1. Hondata Group N Civic Type-R ECU reflash - This sets the rev limit to 8,600rpms, and lowers VTEC engagement to 5,400rpms, and 3,800 if you're at full-throttle / wide-open throttle. - £548.94 (from TDi-North - excludes 17.5% VAT)
As of now, K-pro will not work.
2. B106 Carbon Fiber battery - This will save you 12-13kg over the front axle for about £150. It will not be able to handle aftermarket amplifiers/sound systems, but will open up a good amount of extra space in your engine bay.
3. Team Dynamics Piggy back Engine ECU - This is still in development though the final product is imminent, it is on our development car at the moment. They are anticipating the final product twinned with the exhaust system and induction kit to achieve an increase of 45 BHP from the standard car. This does not involve anything more than the ECU and brackets, there are no internal engine modifications required.
4. Earthing kits £25 - PM "tp" for this. ucp.php?i=pm&mode=compose&u=4198
5. Mugen Group N ECU - +10 HP max power, + 10 HP max torque, drive-by-wire recalibration, no VSA. - €2,150.00
6. Dimsport reflashed ECU - Below 4700/4500 rpm the K20Z4 engine is always on the low cam, above 5400 rpm the K20Z4 engine is always on the high cam, between 4700/4500 rpm and 5400 rpm the K20Z4 is on the low cam at part throttle switching to the high cam at full throttle. - 499.00EUR
Brakes:
The front brake pads are the same kind as used on the S2000, EP3, and the AUSDM DC5. The rears, though, are unique to the FN2.
1. ABP - larger than stock brake kits can be bought for a lot cheaper than the stock brakes.
2. Powerslot 348mm fronts are £399.00 inc Vat for the kit plus Pads and either fitting or P&P. (from ABP Motorsport)
3. Ferodo DS2500 front pads - £76.24
4. Ferodo DS2500 rear pads - £tbc
5. Goodridge S/S brake lines - £tbc
6. Team Dynamics Brake Kit - Calipers, 4-piston road specification types with a black or red finish. Discs, Ø330x26mm thick, 48 cooling vanes, 8 grooves per brake face, bolted to alloy bell centres. Ferodo DS2500 pads, Hose adaptors to convert standard Honda hose to suit APR caliper hydraulic feed. Brake fluid, 1Ltr high temp DOT 5.1. All mounting bolts, washers’ nuts etc - £1500 + vat
7. Rotora Big Brake Conversion - Available in 4 or 6 pot front 330mm/355mm discs and 2 pot 330mm discs rear. Available through xopowertuning.co.uk.
- 4 pot 1 piece 330mm front £1151.
- 4 pot 2 piece 330mm front £1695.
- 4 pot 2 piece 355mm front £1950.
- 6 pot 2 piece 330mm front £2120.
- 2 pot 330mm rear £1340
8. K-sport big brake kit 8 pot 330mm disk - Part No. HO33
9. Alcon big brake kit 343x32 6 pot - £2,300 incl VAT
10. Front EBC Redstuff Ceramic pads £65.00 inc vat (ABP Motorsport)
11. Rear EBC Redstuff Ceramic pads - massively reduces the amount of that nasty rear brake dust that blights the FN2 £50.00 inc vat (ABP Motorsport)
12. Tarox Slotted Front Brake Discs - £199 available at CPL Racing
13. Tarox Slotted Rear Brake Discs - £169 available at CPL Racing
14. CPL Racing Braided Brake Lines (Set of Front and Rear) - £76.60
15. Tarox big brake kit - 6 pot B32 piston calipers with 330mm discs. The kit comes complete with calipers, mounting brackets, discs with seperate mounting bells, stainless steel braided hoses and pads applicable to the intended use. - £1499.00
16. D2 big brake kits (from 12tune.nl):
- 6pot 286mm - €1,299.00
- 6pot 304mm - €1,399.00
- 8pot 330mm - €1,499.00
- 8pot 356mm - €1,649.00
- 12pot 380mm - €2,699.00 (please note that you will need a minimum wheel size of 19" to fit the rotors)
- 12pot 400mm - €2,999.00 (please note that you will need a minimum wheel size of 19" to fit the rotors)
17. STOPTECH 4pot big brake kit - includes 328 x 28mm fully floating grooved rotors with alluminium bells, 4-pot calipers in either Red or Black, Front stainless steel brake hoses INCLUDING the fluid distribution blocks that bolt to the chassis, Set of front AXXIS ULT Ceramic brake pads (other options available for track use if required), Full fitting kit and instructions. If you have the 18" or 19" OE wheels, you will need a set of 15mm spacers (Eibach makes some); most aftermarket 18" wheels with an offset of ET40 or ET45 will not need a spacer. - £1,495 including VAT (from ABP Motorsport) (price will raise once the first 10 units have been sold)
18. STOPTECH replacement (OE-sized) grooved discs:
- Front - £190 inc. VAT (from ABP Motorsport)
- Rear - £150 inc VAT (from ABP Motorsport)
- Front & Rear - £300 inc VAT (from ABP Motorsport)
19. Goodridge braided hoses
Transmission:
1. Quaife LSD - The Quaife LSD from other k20 motors will fit the FN2. - £525.00
2. Toda hi-power clutch/flywheel kit - £630.00
3. Competition Clutch twin plate clutch/flywheel kit - £812.50
4. Toda organic clutch kit - £355.50
5. Toda lightened flywheel - £270.00
6. Team Dynamics Limited Slip Differential - £550
7. Clutchmasters Stage 1 Clutch - £312.31 available at CPL Racing
8. Clutchmasters Stage 3 Clutch - £345.53 available at CPL Racing
9. Clutchmasters Stage 4 Clutch - £320.44 available at CPL Racing
10. Clutchmasters Lightweight Aluminium Flywheel - £234.89 available at CPL Racing
Exterior Modifications:
1. Honda OEM front and rear diffusers - ~£800, can be had for cheaper if bought from places like eBay.
2. Team Dynamics BTCC body kit -
- Front bumper - £650
- Pair of front wings - £450
- Pair of Rear arches - £350
- Pair of Sill extensions - £150
- Rear wing – available on request.
- Inner door cards
3. OEM style Carbon Spoiler - €349.00 (from typerkits.com)
4. OEM style Carbon Bonnet - €595.00 (from typerkits.com)
Misc.:
1. Team Dynamics Roll Cage
2. Carbon Fiber Radiator Cooling Cover - €219,00 from showoffimports.nl
3. JTune Extreme kit - Intake + Battery Relocation kit + Header + Cat + Exhaust + both rear muffler sections and our Extreme flash ECU. This will get you 160kw at the wheels = 215whp. Should be released within the next 3months (updated 05SEP) - approx. £2,581 + shipping
4. Aftermarket cylinderhead for the k20/24 engine developed by Larry Widmer of Endyn (very well-respected Honda Tuner) - $550 + shipping from the US.
Page 2 of this thread has a detailed list of JTune's products.
Last edited by wheelconnector on Thu Aug 06, 2009 2:59 pm, edited 84 times in total.
By JohnnoTypeR
#1926126
HID's, A must have, make's the car look so much better, ever 6000k or 8000k.
Exhaust, The two main out there are, the Miltek, and the new HKS system.
Brake's, The stock brake's really dont look good through the 18's and even worse looking through the 19 inch Rage's. Brake kit's are EXPERSIVE but ABP do some bigger disk's that look 10 time's better over stock for a 1/3 of the price.
Induction system's, there's the AEM but most people i know that's got it are not impressed and say it suffer's from heat soak, Hopefully there will be a GRUPPE M soon :???:.
Just a couple of suggestion's and idea's fella. What colour did you go for, plus Spec :thumbup:
By wheelconnector
#1926166
Thanks for the first few mods that I could list. :thumbup:
I'm going for Milano Red. Over here in Luxembourg, things are a bit different. If you get a Type-R, it will come with pretty much every option. The only options you can really pick are the DVD/Navigation systems, the rear park distance sensors, metallic colour, and choice of wheels. HIDs come stock over here as well :-D . The only option I went for were the park distance sensors.
I can't wait. :bigcry: / :WOOT
By wheelconnector
#1927018
bawnebilly wrote:Camber bolts and fast road geometry set-up is a good cost effective mod.
Thanks for your input. :smile:
As for the fast road geometry setup, are you talking about adjusting caster, camber, and toe angle?
Nicko11, thanks for the link :thumbup:
By bawnebilly
#1927424
Yes, the standard set-up is not adjustable, hence the need for threaded camber bolts.
By Nicko11
#1928648
joeke wrote:front and back strutbrace from omp
http://www.banzai-tuning.de
Does anyone have one of these fitted?
If so please can you provide a pic of one installed.
I can see where they would go because the engine bay is full and I cant even see the top of the suspension struts.
By wheelconnector
#1929852
Hondata was the first thing I had on the list (its at the bottom of the list, though) :smile:
Nicko, I used to have a picture, but I cant seem to find it right now. Maybe I can find it when I get home.
The list will also be updated once I get home, to add in all the TDI-north things.
By woolz
#1936647
im getting sick to death of waiting for decent mods to come out for the fn2!
By Nicko11
#1937182
Strut bars can be found here..
http://www.xopowertuning.co.uk/customer ... hp?imid=50
