- Tue Jan 12, 2016 8:29 am
#3848283
Engine Oil and filter service kits at Opie Oils: An OEM quality oil filter and the correct amount of oil for a FULL change, tailored to your specific vehicle - from as little as £17.99
With the Opie Oils engine oil and filter service kit look up guide, we make it easy to find everything you need for your oil change - if you've got a vehicle, WE'VE GOT THE SERVICE KIT FOR IT.
Ensuring that your car has the right engine oil is an important part of keeping it running smoothly. Benefits of an oil change include:
- Correct lubrication
- Cooling
- Cleaning
- Internal component protection
There is also the considerable financial benefit gained when doing this at home and cutting the garage out of the equation - should you choose to take your service kit to the garage then it's good to know that they will be using a top quality oil in your vehicle, rather than the "standard" oil used in garages - it's worth it for the peace of mind.
As part of this, you will also receive an OEM quality oil filter, as well as the option of choosing a top of the range K&N filter that has been matched using an extensive fitment database - you can rest assured that you will be fitting only high quality, and CORRECT products to your vehicle. Combined with this is a FREE disposable filling kit which includes a funnel, gloves and handy wipes - making your oil change easy and mess free!
To get started, simply follow this link and enter your vehicle details to find the specific kit for your vehicle, it's really that easy.
Got a race, track or custom vehicle? Not a problem, get in touch with our recommendation form and we'll match the right products to your specific set up, it's condition and even your style of driving. Alternatively, give us a call on 01209 202 944 and we'll be happy to help!
Don't forget! Combine all of these great benefits with your additional 10% FORUM DISCOUNT. (usually found in our signature)
Until next time
- Oilman
- Cooling
- Cleaning
Until next time
- Oilman
