Go go juice and lubrication.
By 10 Pence Short
#278782
...can easily be found by spending a few seconds with the search function.
This topic has been done to death, and the advice is still the same.
Pretty much all oils that are within the right viscosity range for your conditions should be fine.
Frankly any branded semi-synthetic oil for petrol engines is perfectly OK for use in either the pre or post '04 CTRs.
I bet you want to know which tyres to go for now, don't you? :roll:
By oilman
#396364
This is probably the longest post on this Forum but certainly one of the most interesting and relevant to all owners of performance cars.
It is the "FULL" unedited transcript of the article written by John Rowland (Chief R&D Chemist for Silkolene) with 40 years experience.
It is great educational reading as it is written by a Chemist, not a Salesman so totally based in facts - If you do one thing, read this, it's worth it! This is a definative article on oils.............
I do not work for Silkolene and I have Johns express permission to post this article to clear up as he would term "the mis-information" on the internet.
Lubricating the Subaru. (or any performance, re-mapped, modded car)
Basically
Basically, to use that irritating in-word, engine lubrication is simple, and consequently boring. So I intend to treat the subject “complicatedly”, which may not be an in-word, but makes life far more interesting!
So, to take a quick look at the simple picture; the oil keeps moving parts apart, reducing friction and carrying away heat. Where there is metal-to-metal contact there are chemicals in the oil to reduce damage. Because the internal combustion process is always less than perfect, some soot is produced and this must be washed off the pistons and rings by the oil, so it has a cleaning or detergent function as well.
The trouble is, all this is just as true for Henry Ford’s original Model T engine as it is for the Subaru or any other high output motor. So where is the difference? The Model T, with 10bhp/litre at 2,000rpm and a single underhead camshaft, was filled with a thick, greenish liquid from somewhere near the bottom of the distillation colums on the Pennsylvania oilfields. It did a vague tour of the internals by guesswork (there was no oil pump) at a temperature around 50 degC, and lasted for 1,000 miles. On the plus side, some of the impurities acted as anti-wear and detergent chemicals. They didn’t work very well, but it was better than nothing. The engine wore out in around 20,000 miles, but even ordinary people, not just amateur rally drivers, were happy to put up with this.
The difference begins with the first turn of the key. The modern high-pressure pump would cavitate on the old heavy monogrades, starving the bearings for a vital couple of seconds, even in warm weather. Likewise, cam lobes would suffer as the sluggish oil found its way along narrow oil ways to the valve gear. The turbo bearing (if fitted as the handbooks say) already spinning fast, would also starve, and when it got going, how long would it be before the heat soak-back fried the primitive oil into a lump of carbon? (This was the problem with “modern” oils only 15 years ago).
So, a good oil must be quite low in viscosity even in the cold, so that it gets around the engine in a fraction of a second on start-up. On the other hand, it must protect engine components (piston rings for example) at temperatures up to 300 degC without evaporating or carbonising, and maintain oil pressure.
Unmodified thin oils simply can’t manage this balancing act. The answer is to use a mixture of thin oil and temperature-sensitive polymer, so as the thin oil gets even thinner with increasing temperatures as the engine warms up, the polymer expands and fights back, keeping the viscosity at a reasonable level to hold oil pressure and film thickness on the bearings. This is called a multigrade.
But, this is all too basic! What I have just written was and is relevant to a 1958 Morris Minor.
The questions that Subaru owners need to ask are: “Will this thin oil evaporate and be drawn into the intake manifold (via the closed circuit crankcase ventilation), leading to combustion chamber deposits and de-activated catalysts?” and “Will the polymer shear down at high engine revolutions and high temperatures, causing low oil pressure and component wear?” and “Will it carbonise on the turbo bearing?” These are 21st century questions which cannot be answered by a basic 1990’s approach.
BUT! Before we head into more complications, some figures………
The SAE Business (American Society of Automotive Engineers)
Viscosity is the force required to shear the oil at a certain speed and temperature. Oils work because they have viscosity; the drag of a rotating part pulls oil from a low-pressure area into a high pressure area and “floats” the surfaces apart. This is called “hydrodynamic lubrication”, and crank bearings depend on it. In fact a plain bearing running properly shows literally no metal-to-metal contact. Experimental set-ups have shown that electrical current will not flow from a crank main bearing to the shells. Also, the energy loss due to friction (the co-efficient of friction) is incredibly low, around 0.001. So for every kilogram pulling one way, friction fights back with one gram. This is very much better than any “dry” situation. For example, the much over-rated plastic PTFE has a co-efficient of friction on steel of 0.1, 100 times worse than oil.
Oil viscosities are accurately measured in units called “Centistokes” at exactly 100 degC. These fall into five high temperature SAE catagories:-
SAE No. 20 30 40 50 60
Viscosity Range 5.6 - <9.3 9.3 - <12.5 12.5 - <16.3 16.3 - <21.9 21.9 - <26
A decent quality oil usually has a viscosity that falls in the middle of the spec, so a SAE 40 will be about 14 Centistoke units, but SAE ratings are quite wide, so it’s possible for one 40 oil to be noticeably thicker or thinner than another.
When the polymer modified multigrades appeared, a low temperature range of tests were brought in, called “W” for winter (it doesn’t mean weight). These simulate cold starta at different non-ferrous monkey endangering temperatures from –15 degC for the 20w test to a desperate –35 degC for 0w. So, for example, an SAE 5w-40 oil is one that has a viscosity of less than 6600 units at –30 degC, and a viscosity of about 14 units at 100 degC.
Now, those of you who have been paying attention will say “Just a minute! I thought you said these multigrade polymers stopped the oil thinning down, but 6600 to 14 looks like a lot of thinning to me!”. Good point, but the oil does flow enough to allow a marginal start at –30 degC, and 14 is plenty of viscosity when the engine is running normally. (A lot more could damage the engine. Nobody uses the 24 viscosity SAE 60 oils any more.) The vital point is, a monograde 40 would be just like candle wax at –30 degC, and not much better at –10 degC. It would even give the starter motor a fairly difficult time at 0 degC. (At 0 degC, a 5w-40 has a viscosity of 800 but the monograde 40 is up at 3200!)
Another basic point about wide ranging multigrades such as 5w-40 or 0w-40 is that they save fuel at cruising speeds, and release more power at full throttle. But complications arise……..
Building a good oil
A cave may not be the best place to live, but it’s ready-made and cheap. This is the estate agent’s equivalent of an old style monograde oil. Or you could get Hengist Pod to fit a window and a door; this is moving up to a cheap and cheerful mineral 20w-50. But an architect-designed “machine for living in”, built up brick by brick, is an allegory of a high performance synthetic oil.
It is impossible to make a good 5w-40, or even 10w-40, using only mineral oil. The base oil is so thin, it just evaporates away at the high temperatures found in a powerful engine that is being used seriously. Although there are chemical compounds in there to prevent oil breakdown by oxygen in the atmosphere (oxidation) they cannot adequately protect vulnerable mineral oil at the 130 degC plus sump temperatures found in hard worked turbocharged or re-mapped engines.
Synthetics are the answer. They are built up from simple chemical units, brick by brick so as to speak; to make an architect-designed oil with properties to suit the modern engine.
But sometimes, if you look behind the façade, there is a nurky old cave at the back! This is because the marketing men have been meddling!
The Synthetic Myth
What do we mean by the word “synthetic”? Once, it meant the “brick by brick” chemical building of a designer oil, but the waters have been muddied by a court case that took place in the USA a few years ago, where the right to call heavily-modified mineral oil “synthetic”, was won. This was the answer to the ad-man’s dream; the chance to use that sexy word “synthetic” on the can….without spending much extra on the contents! Most lower cost “synthetic” or “semi-synthetic” oils use these hydrocracked mineral oils. They do have some advantages, particularly in commercial diesel lubricants, but their value in performance engines is marginal.
TRUE synthetics are expensive (about 6 times more than top quality mineral oils). Looked at non-basically there are three broad catagories, each containing dozens of types and viscosity grades:-
PIB’s (Polyisobutanes)
These are occasionally used as thickeners in motor oils and gear oils, but their main application is to suppress smoke in 2-strokes.
The two important ones are:
Esters
All jet engines are lubricated with synthetic esters, and have been for 50 years, but these expensive fluids only started to appear in petrol engine oils about 20 years ago. Thanks to their aviation origins, the types suitable for lubricants (esters also appear in perfumes; they are different!) work well from –50 degC to 200 degC, and they have a useful extra trick.
Due to their structure, ester molecules are “polar”; they stick to metal surfaces using electrostatic forces. This means that a protective layer is there at all times, even during that crucial start-up period. This helps to protect cams, gears, piston rings and valve train components, where lubrication is “boundary” rather than “hydrodynamic”, i.e. a very thin non-pressure fed film has to hold the surface apart. Even crank bearings benefit at starts, stops or when extreme shock loads upset the “hydrodynamic” film. (Are you listening, all you rally drivers and off road fanatics?)
Synthetic Hydrocarbons or POA’s (Poly Alpha Olefins)
These are, in effect, very precisely made equivalents to the most desirable mineral oil molecules. As with esters, they work very well at low temperatures, and equally well when the heat is on, if protected by anti-oxidants. The difference is, they are inert, and not polar. In fact, on their own they are hopeless “boundary” lubricants, with LESS load carrying ability than a mineral oil. They depend entirely on the correct chemical enhancements.
PAO’s work best in combination with esters. The esters assist load carrying, reduce friction, and cut down seal drag and wear, whilst the PAO’s act as solvents for the multigrade polymers and a large assortment of special compounds that act as dispersants, detergents, anti-wear and oxidant agents, and foam suppressants. Both are very good at resisting high-temperature evaporation, and the esters in particular will never carbonise in turbo bearings even when provoked by anti-lag systems.
Must Have MORE Power!
Motorcars are bought for all sorts of reasons, but enthusiasts like lots of power. To get more power, a lot of fuel must be burnt, and more than half of it, sadly, gets thrown away as waste heat. For every litre of fuel burnt, 60% of the energy goes as waste heat into the exhaust and cooling system. A turbocharger can extract a few percent as useful energy and convert it into pressure on the intake side, but only 40-45% is left, and only 25% actually shows up as BHP at the flywheel. 6% goes in pumping air into the engine, 6% as oil drag losses and 2-3% as engine friction. The oil deals with 97% of the friction; so reducing the remaining few percent is not easy. If you doubt that even ordinary oil has a massive effect, take a clean, dry 200 bhp engine, connect it to a dyno and start it up. It will only make 1 bhp for a few seconds. Now that’s real friction for you!
Oddly enough, people get starry-eyed about reducing friction, especially those half-wits who peddle silly “magic additives”, which have not the smallest effect on friction but rapidly corrode bearings and wallet contents. In fact, even a virtually impossible 50% reduction in the remaining engine friction would be no big deal, perhaps one or two bhp or a couple of extra miles per gallon.
Even More Power!
He place to look for extra power is in that 6% lost as oil drag. In a well-designed modern motor, the oil doesn’t have to cover up for wide clearances, poor oil pump capacity or flexy crankshafts, so it can be quite thin. How thin? Well take a look at these dyno results.
A while ago now, we ran three Silkolene performance oils in a Honda Blackbird motorcycle. this fearsome device is fitted with a light, compact, naturally aspirated 1100cc engine which turns out 120+ bhp at the back wheel. The normal fill for this one-year-old engine was 15w-50, so the first reading was taken using a fresh sump-fill of this grade. (The dyno was set up for EEC horsepower, i.e. Pessimistic)
15w-50
Max Power 127.9 bhp @ 9750 rpm
Torque 75.8 ft-lbs @ 7300 rpm
After a flush-out and fill up with 5w-40 the readings were;
5w-40
Max Power 131.6 bhp @ 9750 rpm
Torque 77.7 ft-lbs @ 7400 rpm
Then we tried an experimental grade, 0w-20 yes, 0w-20! This wasn’t as risky as you may think, because this grade had already done a season’s racing with the Kawasaki World Superbike Team, giving them some useful extra power with no reliability problems. (But it must be said, they were only interested in 200 frantic miles before the engines went back to Japan)
0w-20
Max Power 134.4 bhp @ 9750 rpm
Torque 78.9 ft-lbs @ 7400 rpm
In other words, 3.7 bhp / 2.9% increase from 15w-50 to 5w-40, a 2.8 bhp / 2.1% increase from 5w-40 to 0w-20 or a 6.5 bhp / 5% overall. Not bad, just for changing the oil! More to the point, a keen bike owner would have paid at least £1000 to see less improvement than this using the conventional approach of exhaust/intake mods, ignition re-mapping etc.
Am I recommending that you use 0w-20 in your Subaru’s? Well, perhaps not! The 5w-40, which is a “proper” PAO/Ester shear-stable synthetic, will look after a powerful engine better than a heavier viscosity “cave at the back” conventional oil, and provide a useful extra few BHP.
The End
However, as with all good things in life, we don’t live in a world of perfect motor cars and therefore we have to look at the lubrication trade-off between longevity, reliability, power and cost, relative to the vehicle in which the oil is being used (a scruffy old XR2i with 192,000 miles on the clockis a very different proposition to your spanking new Impreza). Which is why Subaru (and probably your local dealer) recommends a 10w-50 (Such as PRO S); you could look at a 5w-40 for competition and track-day use, but only the most committed competitor would want, or need, the 0w-20 for the extra 5% power.
Now, that's definative!
Simon
#396619
Jack_is_Back wrote: So which oil should I put in my CTR then? :wink: :lol:
The recomended oil for the car is a 0w-40 or 5w-40 fully synthetic depending on what your preference is.
Options are;
Castrol RS Power 0w-40
Mobil 1 0w-40
Total Quartz9000 5w-40
Fuchs Titan Supersyn SL 5w-40
Silkolene ProS 5w-40 (ester)
As you can see there is a few to choose from. If you really want the best oil for your car then the ester based oil is the way to go.
Guy
By Jack_is_Back
#396640
The CTR comes with semi-synthetic from the factory, which is replaced with fully-synthetic by most dealers at first (12 months/12k miles) service. My service invoice actually stated Texaco oil :? I'm unsure of the grades used above.
This fully-synthetic oil had turned black after only 5k miles and the engine sounded a little more harsh than prior to 1st service so I changed the oil (and filter) back to semi-synth 5w-40. It now feels smoother.
Any thoughts my oily friend? :wink:
#396643
Options are;
Mobil 1 0w-40
Guy
recommended by who?
By oilman
#396645
There should be no reason for that, Fully Syns are better than Semi's and it's been proven time and time again.
Certainly the recommended grade is 0w-40 or 5w-40, there are a few Synthetic Blend ones out there but to achieve the 0w or 5w rating it will be a Fully Synthetic as the viscosity range is too wide for a semi.
The perfect oil for your cars is probably the PRO S 5w-40 as it's surface active which will look after the "boundary" lubrication.
Can you email me the relevant page from your handbook and I'll take a look in detail at the recommendations.
Simon
#396650
smartie wrote: recommended by who?
All major oil companies use a "proprietary database" which uses the Manufacturers recommendations for their cars in different climates.
Check your handbook, I'm sure you'll find a table in there, this is what is listed in the database.
Simon
By Jack_is_Back
#396711
oilman wrote:There should be no reason for that, Fully Syns are better than Semi's and it's been proven time and time again.
So the fully synthetic protects my engine better even though it makes it sound a little more harsh??? The difference was quite noticeable - I was constantly checking the oil paranoid that it was low. :roll:
oilman wrote:Certainly the recommended grade is 0w-40 or 5w-40, there are a few Synthetic Blend ones out there but to achieve the 0w or 5w rating it will be a Fully Synthetic as the viscosity range is too wide for a semi.
Hmm, yeah I think the semi-synth I used was 10w-40 actually.
By 03-CTR
#396768
the best oil, without doubt, for a ctr has got to be this :shock: :wink:
Mugen VT-Pro
cheers
w
p.s. there's some new desktops on the main site under the special page bit (top left of page)
interestingly enough, if you go on the special page there's a drop-in air filter available for the ctr (works out about £78 ) as well as some other parts
By oilman
#397634
I guess so looking at the advertisement.
Must confess I've never heard of it, who's it made by?
Anyone have the technical data on it?
Regards
Simon
By munkyf
#397959
Just had a chat with the service bloke at my local dealership. Apparently honda supply their own 0W-20 ultra low viscosity mineral oil with type-r's. Bought a litre of it while I was there.
So where do ppl get this idea that honda are using semi-synth from the factory?
By oilman
#398029
I must confess that I'd heard about this oil and it surprised me that it's a mineral oil as they are incredibly difficult to make due to the 0w rating.
Apparantly they also recommend 0w-30 fully syn as well.
It is a fact that many OEM's are going for thinner viscosities these days due to lack of oil drag, meeting euro 4/5 and petrol consumption requirements.
Whether you use a fully, semi or mineral will only effect oil change periods as mineral oils are less thermally stable than synthetics.
Interestingly, the above mentioned "mineral" oil would need to perform down to -35 degC to meet the 0w rating which is impossible for a mineral oil to do alone and meet sae 20 when hot. I would suspect, in reality it is an MC (Molecularly Converted) mineral oil. The closest synthetic blend to a mineral oil in fact it's just a converted one!
Would love to see a spec sheet on this oil though.
Simon
By 03-CTR
#398279
oilman wrote:I guess so looking at the advertisement.
Regards
Simon
i was only kidding dude.
tbh i haven't a clue who makes it but it has mugen printed on the can so can't be bad :wink:
if you use
http://babelfish.altavista.com/
and whack the mugen site address in you might find some more info on it but i suspect that it only halfrauds regular :lol:
By oilman
#405733
Thought that this would be of interest to you all.
Due to the court case in the states between Mobil and Castrol, you may not always be getting what you think you are so be careful, hydrocracked oils are not synthetics in the true sense of the word as they are molecularly converted petroleum oils, synthetics are not, they are built by chemists in laboratories "brick by brick" and are far superior.
Unfortunately, apart from in Germany, a manufacturer can label the inferior "hydrocracked" oils as synthetics and therefore the only true way of working out the quality is price although even this is not certain as there are some very expensive "hydrocracked" oils out there which are sold on their brand name, Castrol is a good example as they were the Company that Mobil took to court over the labelling issues.
Here is some more reading for those interested:
“HYDROCRACKED” (HC) or MOLECULARLY CONVERTED (MC) BASESTOCKS
There are many petroleum oils available on the market that are so pure and refined, they can now be passed off as synthetics.
They are not made from true synthetic basestocks (at least not in the way that synthetics have traditionally been defined), but they have so little in common with traditional
petroleum basestocks, it is really somewhat silly to classify them as petroleum oils.
Petroleum oil basestocks can be put through a super-extreme refining process called
“hydrocracking”. In some cases, as in the case of one particular name-brand "synthetic" oil, these highly refined petroleum basestocks can actually be termed and sold as "synthetic".
It is completely legal for lubricants manufacturers to label these oils as "synthetic".
These are extremely high performance petroleum basestocks, but they are not truly synthetic the way that most people understand the term and will not necessarily perform to the same level as a premium synthetic oil like PAO (poly alfa olefins) or Esters.
Hydrocracking involves changing the actual structure of many of the oil basestock molecules by breaking and fragmenting different molecular structures into far more stable ones. This results in a basestock which has far better thermal and oxidative stability as well as a better ability to maintain proper viscosity through a wide temperature range - when compared to a typical petroleum basestock.
Although contaminants are still present, and these are still petroleum basestocks, contamination is minimal and performance characteristics are high. This process also can turn a wider range of crude oil stock into well-performing petroleum lubricant basestocks.
TYPES OF SYNTHETIC BASESTOCKS
Synthetic basestocks are not all the same. There are few different chemical types that may be used as synthetic basestock fluids. There are only three that are seen commonly in automotive applications:
Polyalphaolefins (PAO's)
These are the most common synthetic basestocks used in the US and in Europe. In fact, many synthetics on the market use PAO basestocks exclusively. PAO's are also called synthesized hydrocarbons and contain absolutely no wax, metals, sulfur or phosphorous. Viscosity indexes for nearly all PAO's are around 150, and they have extremely low pour points (normally below –40 degrees F).
Although PAO's are also very thermally stable, there are a couple of drawbacks to using PAO basestocks. One drawback to using PAO's is that they are not as oxidatively stable as other synthetics. But, when properly additized, oxidative stability can be achieved.
Diesters
These synthetic basestocks offer many of the same benefits of PAO's but are more varied in structure. Therefore, their performance characteristics vary more than PAO's do. Nevertheless, if chosen carefully, diesters generally provide better pour points than PAO's
(about -60 to -80 degrees F) and are a little more oxidatively stable when properly additized.
Diesters also have very good inherent solvency characteristics which means that not only do they burn cleanly, they also clean out deposits left behind by other lubricants - even without the aid of detergency additives.
They do have one extra benefit though, they are surface-active (electrostatically attracted to metal surfaces), PAO’s are not “polar”, they are “inert”.
Polyolesters
Similar to diesters, but slightly more complex. Greater range of pour points and viscosity indexes than diesters, but some polyolester basestocks will outperform diesters with pour points as low as -90 degrees F and viscosity indexes as high as 160 (without VI additive improvers). They are also “polar”.
Other synthetic basestocks exist but are not nearly as widely used as those above - especially in automotive type applications. Most synthetics on the market will use a single PAO basestock combined with an adequate additive package to provide a medium quality synthetic lubricant. However, PAO basestocks are not all the same. Their final lubricating characteristics depend on the chemical reactions used to create them.
Premium quality synthetics will blend more than one "species" of PAO and/or will blend these PAO basestocks with a certain amount of diester or polyolester in order to create a basestock which combines all of the relative benefits of these different basestocks.
This requires a great deal of experience and expertise. As a result, such basestock blending is rare within the synthetic lubricants industry and only done by very experienced companies. In addition, although such blending creates extremely high quality synthetic oils, they don't come cheap. You get what you pay for!
Guy
By oilman
#407840
As this is "definitive", it could do with some info about oil additives and other things but, not too much at once I feel!
THE IMPORTANCE OF THE ADDITIVE PACKAGE
Although the basestock of an oil will be a major determining factor in the lubrication quality of an oil, chemical additives play a major part in making sure that it does all that it is supposed to do. The chemical additive package of an oil is just as important to insuring the quality of a lubricant as is the particular basestock used.
The chemical additive package of an oil is designed to perform a number of tasks and each task is performed by a particular type of chemical. The quality of the chemicals used and the manner in which they are blended plays a large part in determining how well the additive package does its job.
As the quality of the additive chemicals increases, so does the price. In addition, proper blending takes a great deal of research. This requires much time and, again, money. Therefore, manufacturers will, of course, charge more for motor oils which contain a high quality additive package than those with lower quality additive packages. They simply can't afford not to.
Each chemical within an oils additive package plays a different role in boosting the beneficial properties of it's host lubricant (basestock).
The additive package must perform the following roles:
IMPROVE VISCOSITY CHARACTERISTICS
Basestock lubricants have a certain temperature range over which they will flow adequately. The wider this temperature range the better. Cold temperature starting requires an oil that will flow well at low temperatures. The higher engine temperatures of todays smaller, higher revving engines requires an oil that will perform well under high temperature conditions.
Pour Point Depressants
In order to improve the flow characteristics of a lubricant basestock at low temperatures additives called pour point depressants are used. Because synthetic basestocks have inherently better low temperature flow characteristics, pour point depressants are typically unnecessary. Therefore, they are normally only used in conjunction with petroleum basestock lubricants.
Waxy contaminants within petroleum basestocks tend to crystalize in low temperature conditions. These crystalized structures absorb oil and increase in size. This leads to oil thickening and poor low temperature flow characteristics. Pour point depressants do not inhibit this crystallization, as is thought by many. Instead, the pour point depressants are absorbed into the crystals instead of the oil, thereby lowering the volume of the crystals in proportion to the volume of the free flowing oil. This helps maintain the low temperature flow characteristics of the base oil even when crystallization occurs.
CHEMICAL ADDITIVES
Higher quality petroleum basestocks have less need for pour point depressants because they have lower levels of wax contamination. However, complete dewaxing of a petroleum basestock is not very economical, so all petroleum basestocks require at least some level of pour point depressant.
Viscosity Index Improvers
As a lubricant basestock is subjected to increasing temperatures it tends to lose its viscosity. In other words, it thins out. This leads to decreased engine protection and a higher likelihood of metal to metal contact. Therefore, if this viscosity loss can be minimized, the probability of unnecessary engine wear will be reduced.
This is where viscosity index (VI) improvers come in.
VI improvers are polymers that expand and contract with changes in temperature. At low temperatures they are very compact and affect the viscosity of a lubricant very little. But, at high temperatures these polymers "expand" into much larger long-chain polymers which significantly increase the viscosity of their host lubricant.
So, as the basestock loses viscosity with increases in temperature, VI improvers “fight back” against the viscosity drop by increasing their size. The higher the molecular weight of the polymers used, the better the power of "thickening" within the lubricant. Unfortunately, an increase in molecular weight also leads to an inherent instability of the polymers themselves. They become much more prone to shearing within an engine.
As these polymers are sheared back to lower molecular weight molecules, their effectiveness as a VI improver decreases. Unfortunately, because petroleum basestocks are so prone to viscosity loss at high temperatures, high molecular weight polymers must be used. Since these polymers are more prone to shearing than lower molecular weight polymers, petroleum oils tend to shear back very quickly. In other words, they lose
their ability to maintain their viscosity at high temperatures.
Synthetic basestocks, on the other hand, are much less prone to viscosity loss at high temperatures. Therefore, lower molecular weight polymers may be used as VI improvers.
These polymers are less prone to shearing, so they are effective for a much longer period of time than the VI improvers used in petroleum oils. In other words, synthetic oils do not quickly lose their ability to maintain viscosity at high temperatures as petroleum oils do.
In fact, some synthetic basestocks are so stable at high temperatures they need NO VI improvers at all. Obviously, these basestocks will maintain their high temperature viscosities for a very long time since there are no VI improvers to break down.
MAINTAIN LUBRICANT STABILITY
Lubricating oils are not only prone to viscosity loss over time. They are also susceptible to breakdown due to contamination and/or oxidation which decreases the useful life of an oil. Additives are often used in order to inhibit the susceptibility of a basestock to this breakdown over time.
Detergents and Dispersants
Contamination due to sludge and varnish build-up within an oil can often be one of the limiting factors in determining the useful life of an oil. If this build-up can be minimized and contained, the life of the lubricating oil can be increased. Detergent and dispersant additives are utilized for this purpose. There is some debate as to whether those additives considered to be detergents actually "clean" existing deposits, but at the very least they aid dispersants in keeping new deposits from forming. Detergent and dispersant additives are attracted to sludge and varnish contaminants within a lubricant. They then contain and suspend those particles so that they do not come together to form deposits. The more contamination within the oil, the more additive that is used up.
Since synthetic oils are less prone to leave sludge and varnish, these additives are used up much more slowly within a synthetic lubricant.
Some oils use ashless dispersants which are more effective at controlling sludge and varnish contamination than metallic dispersants. In addition, some ashless dispersants are actually long chain polymers that serve a dual purpose as VI improvers in multi-grade oils.
Detergents are all metallic in nature.
Anti-Foaming Agents
Although necessary for engine cleanliness, detergents and dispersants can have a negative effect on the lubricating fluid within your engine as well. Sometimes, these oil additives can play a part in oil foaming. In other words, air bubbles are produced within the oil. These air bubbles, if not neutralized, will reduce the lubricating qualities of the motor oil. Anti-foaming agents such as small amounts of silicone or other compounds are used to control this phenomenon.
Oxidation Inhibitors (antioxidants)
Oxidation inhibitors are additives that manage to reduce the tendency of an oil to oxidize (chemically react with oxygen). They are also called antioxidants.
The antioxidant reacts with the peroxides in the oil. These peroxides are involved in the process of oxidation. Reaction with the antioxidant removes them from the oxidation process, thereby lessening the chance of motor oil oxidation.
Oxidation inhibitors also serve one more very important purpose. They protect against bearing corrosion. Bearing corrosion is caused by acids within your motor oil. These acids come from combustion by-products, but they can also be the result of oxidation. So, by inhibiting motor oil oxidation, antioxidants also protect against bearing corrosion.
Corrosion Inhibitors
Although antioxidants prevent the acids caused by oxidation, they do nothing to neutralize the acids caused by combustion by-products. Therefore, other additives must be used in order to keep these acids in check and to protect engine components from their effects.
Some corrosion inhibitors are designed to protect non-ferrous metals by coating them so they cannot come in contact with acids within the oil. Other corrosion inhibitors are designed to actually neutralize the acids within the oil.
Anti-Wear Agents
Even with the best of oils there is always the possibility of metal to metal contact within an engine, however slight. Some oils (especially ester synthetics) will cling to metal surfaces better than others, but engines that are left to sit for any period of time may have very little lubricant protection at start-up.
This is especially true in cold conditions when petroleum oils do not pump well. To minimize the engine component wear caused by these situations, anti-wear additives are used. Additives such as zinc and phosphorus will actually coat metal surfaces forming a protective barrier against wear. They do not eliminate the metal to metal contact. They simply minimize the wear that occurs during those instances.
ALLEVIATE COMPATIBILITY ISSUES
Some additives are included in an oil to deal with compatibility issues between the oil and certain engine components. For instance, there are certain types of lubricant basestock that will cause seals and gaskets to swell or to shrink. These effects have to be minimized. Sometimes basestock blending will alleviate the issue, but in other cases additives
might be used.
Depending upon the particular application the oil will be used for, some additives may be left out while others may be left in. For instance, in order to meet API SL fuel economy requirements, oils are now formulated with special friction modifiers. However, these friction modifiers can cause clutch slippage if used within motorcycle oils. So, motorcycle specific oils do not contain these friction modifier additives.
When considered as a whole, Engine oils are comprised mainly of basestock fluids. Only a small percentage of the oil is comprised of additive chemicals. However, addditives can play as important a role as the basestock fluid itself.
A high quality basestock blended with a cheap additive package will be poor oil. A high quality additive package added to a cheap basestock is no better.
Of course, a motor oil as a whole is far greater than the sum of its parts. In other words, even a high quality basestock combined with a high quality additive package isn't necessarily going to yield a great oil. The company manufacturing the oil has to know how to correctly blend those basestocks and additives so that they perform well together.
Simon
#417452
Options are;
Mobil 1 0w-40
Guy
I know there is a lot of info on here already but the dealers say 10W40 semi synth. Why go for synth.
#417911
johnmglen wrote: I know there is a lot of info on here already but the dealers say 10W40 semi synth. Why go for synth.
Here is the manufacturer recomendation for the Civic Type R.
Lubricant report for:
Honda, Civic 2001, Civic 2.0 16V Type R, (2.0 Typ R VTEC),2001-
Manufacturer: Honda Motor Co. Ltd., Tokyo, Japan
Drive type: f.w.d.
Cilinder capacity: 1998 cc
Power output: 200 HP/147 kW at 7400 rpm
Engine, petrol, 4-stroke, water cooled, 4 valves/cyl.
Capacity 4.50 liter
Filter capacity: 0.20 liter
Change every 20000 km or 12 months
Check daily
OEM recommendation
Year-round API: SJ-EC SAE 0W-20
Year-round API: SJ-EC SAE 0W-30
Year-round API: SJ-EC SAE 0W-40
Year-round API: SJ-EC SAE 5W-30
Year-round API: SJ-EC SAE 5W-40
The manufacturer does not recomend 10w-40 for year round use!
The semisynthetic option is cheeper, this is why the car comes with semisynth in it, to keep production costs down. However Fully synthetic oil is better than semisynth.
If the dealer has recomended semisynth, thats fine but you can do better. Is this 10w-40 the oil the dealer would use on one of their services? if so its probably down to cost.
I have listed some of the advantages of moving to a fully synth below.
Synthetic basestock molecules are pure and of uniform size. This is because synthetic basestocks are designed from the ground up with the sole purpose of protecting your engine. Nothing is added if it does not significantly contribute to the lubricating ability of the oil.
In addition, in top-quality synthetics, no component is added which might be contaminated with any substance that might lessen the lubricating qualities of the oil. In other words, manufacturers of these premium synthetics implement very strict quality control measures to insure no contamination.
Not only that, synthetic basestocks are designed so that the molecules are of uniform size and weight. In addition, synthetic basestock molecules are short-chain molecules which are much more stable than the long-chain molecules that petroleum basestocks are made of. This significantly adds to the lubricating qualities and stability of the oil.
EXTENDED OIL DRAINS
Stable Basestocks
Synthetic oils are designed from pure, uniform synthetic basestocks, they contain no contaminants or unstable molecules which are prone to thermal and oxidative break down.
Moreover, because of their uniform molecular structure, synthetic lubricants operate with less internal and external friction than petroleum oils which have the non-uniform molecular structure. The result is better heat control, and less heat means less stress to the lubricant.
Higher Percentage of Basestock
Synthetic oils contain a higher percentage of lubricant basestock than petroleum oils do.
This is because multi-viscosity oils need a great deal of pour point depressant and viscosity modifying additives in order to be sold as multi-viscosity oils.
Synthetic oils, require very little in the way of pour point depressants and viscosity modifiers. Therefore, synthetic oils can contain a higher percentage of basestock, which actually does most of the lubricating anyway. More basestock leads to longer motor oil life.
Additives Used Up More Slowly
Petroleum basestocks are much more prone to oxidation than synthetic oils, oxidation inhibitors are needed in greater supply and are used up very quickly. Synthetic oils do oxidize, but at a much slower rate therefore, oxidation inhibiting additives are used up much more slowly.
Synthetic oils provide for better ring seal than petroleum oils do. This minimizes blow-by and reduces contamination by combustion by-products. As a result, corrosion inhibiting additives have less work to do and will last much longer than within a petroleum oil.
Excellent Heat Tolerance
Synthetics are simply more tolerant to extreme heat than petroleum oils are. When heat builds up within an engine, petroleum oils quickly begin to burn off. They volatize. In other words, the lighter molecules within petroleum oils turn to gas and what's left are the large petroleum oil molecules that are harder to pump.
Synthetics are resistant to this burn-off. They will tolerate much higher engine temperatures.
EXTENDED VEHICLE LIFE WITH FEWER REPAIRS
Heat Reduction
More often than not, vehicle life is determined by engine life. One of the major factors affecting engine life is component wear and/or failure, which is often the result of high temperature operation. The uniformly smooth molecular structure of synthetic oils gives them a much lower coefficient of friction (they slip more easily over one another causing less friction) than petroleum oils.
Less friction, of course, means less heat in the system. And, since heat is a major contributor to engine component wear and failure, synthetic oils significantly reduce these two detrimental effects.
In addition, because of their uniform molecular structure, synthetic oils do not cause the "blanket effect" which was mentioned earlier. Since each molecule in a synthetic oil is of uniform size, each is equally likely to touch a component surface at any given time, thus moving a certain amount of heat into the oil stream and away from the component. This makes synthetic oils far superior heat transfer agents than conventional petroleum oils.
Greater Film Strength
Petroleum motor oils have very low film strength in comparison to synthetics. The film strength of a lubricant refers to it's ability to maintain a film of lubricant between two objects when extreme pressure and heat are applied.
Synthetic oils will typically have a film strength of 500% to 1000% higher than petroleum oils of comparable viscosity. In fact, believe it or not, even though heavier weight oils typically have higher film strength than lighter weight oils, a 0w30 or 5w-40 weight synthetic oil will likely have higher film strength than a 15w40 or 20w50 petroleum oil.
Thus, even with a lighter weight oil, you can still maintain proper lubricity and reduce the chance of metal to metal contact when using a synthetic oil. Of course, that means that you can use oils that provide far better fuel efficiency and cold weather protection without sacrificing engine protection under high temperature, high load conditions. Obviously, this is a big plus, because you can greatly reduce both cold temperature start-up wear and high temperature/high load engine wear using the same low viscosity oil.
Engine Deposit Reduction
In discussing some of the pitfalls of petroleum oil use, engine cleanliness is certainly an issue. Petroleum oils tend to leave sludge, varnish and deposits behind after thermal and oxidative break down. They're better than they used to be, but it still occurs.
Deposit build-up leads to a significant reduction in engine performance and engine life as well as increasing the number of costly repairs that are necessary. Since synthetic oils have far superior thermal and oxidative stability than petroleum oils, they leave engines virtually varnish, deposit and sludge-free.
Better Cold Temperature Fluidity
Synthetic oils and other lubricants do not contain paraffins or other waxes which dramatically thicken petroleum oils during cold weather. As a result, they tend to flow much better during cold temperature starts and begin lubricating an engine almost immediately. This leads to significant engine wear reduction, and, therefore, longer engine life and fewer costly repairs.
IMPROVED FUEL MILEAGE AND PERFORMANCE
As indicated earlier, synthetic oils, because of their uniform molecular structure, are tremendous friction reducers. Less friction leads to increased fuel economy and improved engine performance.
Any energy released from the combustion process that would normally be lost to friction can now be transferred directly to the wheels, providing movement.
Vehicle acceleration becomes swifter and more powerful while using less fuel in the process.
The uniform molecular structure of synthetic oils has another performance enhancing benefit as well. In a petroleum oil, lighter molecules tend to boil off easily, leaving behind much heavier molecules which are difficult to pump. Certainly, the engine loses more energy pumping these heavy molecules than if it were pumping lighter ones.
Since synthetic oils have more uniform molecules, fewer of these molecules tend to boil off.
More importantly, when they do, the molecules which are left are of the same size and pumpability is not affected.
Hope this helps.
Guy.
By Big_Red
#418929
Thanks for the advice Guy.
Cheers :thumbup:
By Tec
#438608
Very informative!
One quick question and you can tell I'm not a mechanic. Mixing oils, I take it thats to be avoided. If I wanmted to change to fully synth then its best to drain the existing oil out and start afresh?
  • 9
