How to use this forum or technical problems/issues inluding avatar requests.
By smartie
#3824625
The following words in your search query were ignored because they are too common words: glastonbury.
You must specify at least one word to search for. Each word must consist of at least 4 characters and must not contain more than 10 characters excluding wildcards.
By EvoStu
#3824646
smartie wrote:The following words in your search query were ignored because they are too common words: glastonbury.
Will check it. :bigthumb:
By EvoStu
#3824647
I'll add another search index later. :bigthumb:
By EvoStu
#3825723
The new search index is nearly completed, so search results should be considerably better. :bigthumb:
By EvoStu
#3825790
New index created and its pretty epic. Far better than the one we had before and far less disk overhead.
By bearman
#3843894
Has the index gone tits up? Pretty much zero search results being displayed unless they were from a day or 2 ago
By EvoStu
#3843922
We've got some maintenance going on as we're preparing an upgrade.
By EvoStu
#3844042
sitesplat wrote:test the @mention tag type @EvoStu
:Woot:
