EvoStu wrote:Ali wrote:Wrong. Double wishbones allow far greater compliance because you can have greater wheel travel without any disruption of the camber geometry. Wishbones make a better road car because handling and ride quality are far easier to combine. Ironically, torsion beams are fine for track use because track cars have ludicrously stiff suspension anyway, having no need to worry about road surface. Hell, you could nail the wheels to the chassis on a track car and still have decent handling.
So hang on........torsion beams are only good for track use? All the manufacturers who use torsion beam at the moment produce cars which ride perfectly fine and as Pap states (and I've said it lots before) the majority of drivers cannot tell the difference and quite frankly do not care.
Oh by the way I just specced up a Golf GTI to the same spec as my CW edition without any options above what are already standard on the CW.
Total: £26540.00 otr.
Read what's written, think, THEN reply. Wishbones are not only a track biased suspension, contrary to popular belief. They give the ability to have a far better ride while maintaining excellent geometry. Torsion beams are a far bigger compromise, you end up having to sacrifice one for the other. Ask a suspension engineer. I happen to be friends with one...
And I couldn't care what "normal" people can and can't tell the difference between because they buy Passat TDis and Corsas and are clearly idiots. The cars we're talking about are driven by far fussier people who can tell the difference. The Civic would be a better car for real world roads with wishbones all round, unless Honda don't possess an engineer capable of setting up decent geometry and wheel travel.
