Yellow Speed Coilovers
Posted: Sun Jan 21, 2018 7:25 pm
by cobleyjamie
Hi guys, new to the forum.
I have just purchased some YellowSpeed Coilovers I was wondering how people have set them up for the track and if would need camber bolts for them. Thanks in advance.
Re: Yellow Speed Coilovers
Posted: Sun Jan 21, 2018 11:28 pm
Depend on how track you want the set up. Combo of both camber bolts and the adjustable top mounts will give you good amounts of negative camber.
Tie rod arms are the limitation as the more negative camber you induce on the top mounts, the shorter the tie rod arms have to be and in most cases, the arms are too long and require modifying or new ones being fitted.
Posted: Mon Jan 22, 2018 3:01 pm
by cobleyjamie
How would you go about modifying the track rod ends though?
Posted: Mon Jan 22, 2018 6:00 pm
Easiest way is to buy the ones Tegiwa sell.
Before this we would have to source solid tie rod arms (Honda ones are hollow) and get them machined down and thread cut before cutting the length to size.
