Hints and Tips for all things Track Day and 1/4 mile.
By cobleyjamie
#3865743
Hi guys, new to the forum.
I have just purchased some YellowSpeed Coilovers I was wondering how people have set them up for the track and if would need camber bolts for them. Thanks in advance.
By Lewisgame
#3865746
Depend on how track you want the set up. Combo of both camber bolts and the adjustable top mounts will give you good amounts of negative camber.
Tie rod arms are the limitation as the more negative camber you induce on the top mounts, the shorter the tie rod arms have to be and in most cases, the arms are too long and require modifying or new ones being fitted.
By Lewisgame
#3865749
Easiest way is to buy the ones Tegiwa sell.
Before this we would have to source solid tie rod arms (Honda ones are hollow) and get them machined down and thread cut before cutting the length to size.
FK8 Fog light protectors
pm sent
