How much extra fuel should I bring with me? One or two 5 gallon gerry cans?
Assuming my car will burn through a fair share being 300bhp.
Sedge wrote:I'd agree with that. It'll get used at some point so it won't be wasted.Cheers Sedge, yea I had thought that as well, it'll be used up, just didn't wanna get on to keen
Enjoy :salut:
R'ash wrote:I usually get through 2 tanks with mine which is standard power and management, so I guess more than that.Good to know bud thanks [smilie=karls_thumb.gif]
Although on my first one I think I only used just over a tank
Newannaive wrote:Carlos used to take about 4 jerry cans for his jrsc. Lol. It got through it.I bet he was going flat out though, I'm not going try and brake any records
Mark83 wrote:Are there no petrol stations nearby?Not close no, the track is a bit "middle of no where". Just wanted to have an idea if the gerry cans where just to much or pretty accurate. Would rather not leave the track unless I really needed to, through no other reason other than convenience. So If burnt through a tank pretty quick I'd be back and forward to the petrol station all day.
Fire_2 wrote:JRSC fuel starv around high G's corners so keep the tank over 1/4 to stop thisEven with me running road tyres? That that was just semi/slicks?
R'ash wrote:don't forget to take some oil with you swell as you'll go through that more the normal.That's on my list as well, a fresh top up the night before and bringing some with me [smilie=karls_thumb.gif]
think your talking about oil on the semi slicks, but yeah, with low petrol, and high g corners, it can starve, causing it too cough and splutter a bit. even with road tyres.
mjhamilton wrote:And to check your tyre pressure every 15 minute session - you will need to let air out over the day and then once everything cools does use a compressor to put it back In before going home[smilie=karls_thumb.gif]
SeanEP3 wrote:I emptied my tank in around 80 miles at Bedford. you can easily get through two tanks no prob.Looking forward to it for sure, especially with there only being 6 cars going, all of which are valuable. So it means there will be no unnecessary driving techniques.
enjoy it, you will absolutely love it!
kipps wrote:I always go through a full tank (brimmed for the drive there in the morning) and 2 x 20 ltr Jerry cans. I just about make it home each time on fumes from the last canOnly cos you poor it down the side of the car when filling back up dude...(Based on me driving Preston to Oulton and back at approx 45 miles each way)
Mine's not boosted though - I'd probably use alot more if it was![]()
kipps wrote:Im pretty sure that was your fault, you were tasked with the job of holding the funnel, I was pouring ... you failed to locate the funnel correctly into my tank and still owe me £10 for the lost petrol !!!!Did he have problems finding the hole
