Hints and Tips for all things Track Day and 1/4 mile.
By Kenny
#2040827
Been meaning to write this for a while so finally got round to it, hopefully it will encourage more people to take up trackdays, answer the usual FAQ and ease the nerves of first timers.
First and foremost, trackdays are about having fun and driving you car in a way that you can’t on the road. It is not racing!
On your first day DO NOT try to be a trackday hero, most likely you are no where near as fast as you think you are and all you are doing is pissing people off. If someone is behind you lap after lap then you are holding them up, get out the way.
You will learn far more from following faster drivers, than by forcing them to wait behind you. Please also pull over to let them pass as early as possible – do not wait until a faster car is right on your rear bumper, or entering the braking zone before you (indicate and) pull over to let them pass.
At the same time do not drive aggressively behind another driver, give them time to move over. If they don’t, come in and have a word with a marshall rather than lose your temper. Red mist on the track is a bad idea.
Passing is only allowed on the straights with the consent of the driver in front. Correct method is for the driver to recognise a faster car in their mirror, indicate right and pull offline (Overtaking rules may be different on some tracks but this is the general rule) lift off slightly until the car is passed and rejoin the correct racing line.
All this will be explained at the briefing, all drivers must attend this. The organisors will explain of the rules, flags etc. If anything is unclear or you are unsure do not be afraid to ask questions, they will be happy to help.
Most trackdays are open pit lane which means you can go on track whenever your want (at the instruction of the pit lane marshalls) and stay out as long as you want. Total numbers on track are limited at any one time but on open pit days it is rare to have to queue to join the track.
There are also ‘sessioned’ days, usually limited to 20 mins at a time and divided into groups based on experience.
Personally I don’t like the idea of sessioned days, I prefer to go out when I feel like it and stay out as long as the brakes are holding up. An open pit might bit better for your first day. It wont be overcrowded as they limit car numbers on track at any given time, that said it might be quite busy so you could find yourself having to get out of the way till you build up your pace.
Flags
Please ensure that before entering onto the circuit that you are familiar with the following flag signals, as this is the marshal’s only form of communicating with whilst you are on the circuit.
Red Danger Session has been stopped. Check your
mirrors, slow down immediately and proceed to the pits exercising extreme caution.
Yellow Slow Down Your speed at this stage is too high for
safety (or there may be a danger ahead of you). Repeated yellow flags may result in you being removed from the circuit.
Blue Move Over A faster car is stuck behind you and cannot pass.
Please move over to the right of the track as quickly as possible to permit the faster car to pass. The faster car may be slower in a straight line, so you may have to lift off briefly. Repeated blue flags may result in you being removed from the circuit.
Chequered Session Ends Complete the end of the current lap and
return safely to the pits.
Black Return to Pits Your car or driving is a danger to other
participants. Please return to the pits immediately for further information.
Tyres
Tyres, you could completely wreck a brand new set in a day if you wanted to but that requires much arsing around. Provided you still have a few mill of legal tread on them they will still be fine at the end of the day. What you tend to find is the front left will get the heaviest wear on the outside shoulder (on clockwise circuits which most are). However you only tend to notice it after a few trackdays on the same set.Most folk new to trackdays should not really see much wear at all, although over driving the car and being ragged will increase wear. Buy a tyre pressure gauge and check the pressures after every session on track. The pressure will go up with the heat, especially on the heavily loaded tyres. You will kill your tyres unless you lower the pressure. Generally most people run a few psi lower than road levels.
Heavier cars will see more tyre wear then lightweight trackcars.
Some regular trackdayers buy a spare set of wheels to fit track tyres to, to avoid killing their road tyres.
Tip: If you are using semi slick trackday tyres you should give serious consideration to fitting a baffled sump. High g long corners will cause oil starvation which will very rapidly lead to an expired engine.
Brakes
Brakes, make sure you have plenty left on the pads, the OEM are pretty good and will last for a good few trackdays. Make sure your fluid is topped up. If it is old or has been boiled at any time get it changed before tracking it. When on track, if you feel the peddle start to go soft come in immediately! Do not think you can squeeze another lap in as thats a classic noob trackday error and one of the most common causes of trackdays incidents, the brake pedal can go to the floor and you suddenly lose all braking if you ignore the warnings.
You may want to do a cool down lap to help the brakes, remember to keep well offline and watch your mirrors
Tip: When braking, do not follow the car in front to closely. They may have vastly superior braking than you, in which case you will be heading for the tyre wall or they may have poor brakes and you could slam into the back of their car.
Insurance
I don’t bother with trackday insurance myself but with Competition Car Insurance you can expect to pay £10 for every £1k value of the car ie £150 per day for £15,000 car. The excess tends to be huge so it only really covers you for write offs which are very, very rare on track. What you can do is part insure it for a few £k which lowers the excess and covers you for minor prangs, which the majority of trackday incidents are.Worth checking if your insurance company provides trackday insurance, some provide full cover for a reasonable cost.
Remember, trackday insurance only covers you for your own car. If you drive into someone else their car is not covered, you had better hope their car has it’s own insurance or the owner is very easy going!
Cost
Trackdays are not cheap, if you are worried about the cost here is a breakdown of what it’s going to be.
You can expect to pay around £80-£250 for a full day session depending on time of year and track.
A full day will probably use up about 2 tanks of petrol, £100
Brake pads should see at least half a dozen track days. I usually equate this to roughly £25 per day
Tyres should be good for a few trackdays, as mentioned they wear unevenly so you should keep an eye on them, again I would budget £50 per day for tyres.
Instruction
Most circuits and trackdays will have some on hand either FOC or for a small fee. They will be able to help you out a lot with lines, braking points etc.
Never underestimate the value of trackday instruction, even the very best will listen to local knowledge. Even if you think you are doing well you are guaranteed that an instructor will still take seconds off your laptime.
Oil and fuel
Make sure the oil is topped up and take a spare litre with you and continue to check it throughout the day.
Take a spare jerry can of fuel, I get fuel starvation if I run it too low. Not often a problem but remember to check it, its easy to forget when having fun. If you run out on track you will look like a plank and everyone will be pissed off at you for causing an unnecessary red flag.
General advice-
• Remove everything from boot
• Remove everything from inside car! I have been in a car when someone found a plastic bottle under their brake peddle approaching a heavy braking zone. I found it hilarious, the driver not so.
• Take it easy and build up your speed, classic error is to go straight off at the first corner.
• Check your mirrors for faster traffic coming up behind, holding them up gets frustrating but as long as you move over generally etiquette is good and they will give you plenty of space.
• Don’t feel you have to jump out the way as soon as you see them, often those new to it feel that all they are doing is constantly moving over. Trick is to get into the habit of lifting off as early as possible after a corner NOT at the end of the straight. That way both cars lose the least time.
• Just when you think you have the hang of it and are getting quite good, come in to the pits because you're not. That might sound patronising but its sound advice. Its later in the day when sometimes confidence goes overboard and ambition overtakes talent. Some big offs can happen that way so always keep the sensible head on.
• If you go off don’t panic. There are usually gravel traps and plenty of run off area, avoid going into gravel traps sideways, the car can dig into the gravel and roll!
• If the car breaks down on track pull well off the racing line into the infield and get out of the car and over a tyre wall as quick as you can. The marshals will red flag the session so your car can be recovered. DO NOT attempt to work on your car during a live session.
• Remember don’t put the handbrake on in the pits, you will boil your fluid. leave it in gear or chock the wheels.
• Leave a decent amount of time between session for the car to cool, 15-20mins should be fine. If you boil your brake fluid you will be waiting up to an hour for it to cool so that’s another reason for no overdoing it on session lengths. I would suggest 8-10 laps to begin with.
• As well as fuel for the car you will need fuel for you :wink: Trackdays can be hot and hard work, make sure you drink plenty of fluids and eat something. Done myself when getting carried away and not fed myself. You will find your concentration going and you don’t want that on track.
• Being smooth generally equals being fast, if you are throwing the car around you might look spectacular but you won’t be quick.
• To get on track you car should be road legal and well maintained. You will need a helmet, your can use your own or most tracks will have some available for hire.
• Wear long sleeved top and trousers as some circuits require this for insurance reasons.
• Filming is allowed but make sure all camera equipment is well secured and can’t fly about in the event of an off.
• Timing is not allowed is it invalidates the circuits insurance for trackdays, if you are caught timing your laps you may be told to leave!
• You are responsible for any passengers, make sure they have signed on for passenger laps and have attended the briefing.
• Do not speed in the pit lane.
• You may have to show your drivers license so have it with you.
• Have fun. :-D
By evilowl
#2040855
Evilowl's guide to the Nurburgring Nordschleife
Travelling there
Living in the south of the UK we normally grab the Eurotunnel across to Calais - the ferry is fine too but we find the Eurotunnel quick and reliable, and not affected by bad weather, or pikeys doing booze cruises, or coachloads of pensioners and children. If you are travelling from the north of the UK I would recommend getting a ferry from Hull or Newcastle into Holland.
From Calais we head straight into Belgium to Brussels, then nip round the ring road and follow signs to Liege/Luik. There are several ways to travel and most of them are pretty boring, but for a more interesting trip head past Spa Francorchamps and then go cross country towards Blankenheim on the 258 before following that all the way to Nurburg. DO NOT confuse Nuremberg (Nazi rallies) and Nurburg, they are 4 hours drive apart!
There are no tolls on the roads we take, likewise there is no autobahn. Petrol stations appear fairly often and the price is usually comparative to the UK.
The travelling time from Calais to the ring gates is around 4hrs assuming you stick to speed limits. And I recommend you do, because you can be banned on the spot and have your car confiscated if you vastly exceed them and get caught.
For a full set of directions, visit Ben Lovejoy's site and also northloop, both of which I will link to later.
Accommodation / Recommended places to stay
All of the places I have stayed at I would recommend.
http://www.dorint.com/en/conference-hot ... ment-eifel
The Dorint is in a superb position overlooking the grand prix circuit. Quite pricey unless you book well in advance although sometimes you can book and get a non-cancellation rate which reduces the prices a lot. Food is good including continental breakfast. Rooms are large and well equipped. Some of the rooms have balconies overlooking the track, obviously these are very expensive when the F1 is on.
http://www.slidersguesthouse.com/
Sliders guest house is around a 30 minute drive from the track, along lovely windy country roads. Bren and Suzy are lovely people and the prices are excellent, I think we paid around £20 per person per night last time, but this is dependant on euro currency fluctuations. Bren is a true petrolhead and a very experienced ringer, running 7 min 32 second BTG laps on his Yamaha R1. There are videos of him on his website. This place is a B&B only so you will have to travel a few miles to the larger villages for a restaurant. We had a lovely Italian meal in one that Bren recommended.
http://www.am-tiergarten.de/en/home/
The Hotel Am Tiergarten is really nice and my first choice for accommodation. The rooms are great, staff are very friendly. It's also only a 2 minute drive down the road to the ring entrance. Prices are good, food in the attached Pistenklaus restaurant is excellent. I highly recommend you get the steak on a hot stone! This place is also Sabine Schmitz's parent's hotel.
http://www.blaueecke.de/start/
The Blaue Ecke is in Adenau village, approx 10 minute drive from the ring main entrance (there is a second entry and exit point in Adenau village). I haven't actually stayed here but we have been to eat here several times and the food is very good and well priced.
By Jenga_89
#2938121
Great post!
Why cant you time your laps though ?
By haitch
#2938198
Timing implies racing, different insurance for a trackday to a race event. And unless you are a racing driver, whats the point?
By Sir Nodrick
#3550242
Guys, Just to add to this. On our trip, my friends and I stayed here:
http://www.lindner.de/en/hotel_ferienpa ... older_view
Depending which chalet you get, they sleep 6-10 people and it works out quite good value for money when split between you. It is literally accross the main road opposite the bridge under the Nordschleife.
By Danith
#3757695
I've done touristfahrten a couple of times now but this year I'm throwing a track day in too (14th July).
I was worried that my exhaust would be too loud (cobra catback silenced B pipe - but backbox spat all it's wadding and baffles out) but I measured the sound on a phone app and it seems to be 91db at 75% RPM - will it be reet?
Hi All, I've just bought another Ep3 track car to[…]
FINALLY took the plunge !
After 14 fantastic years in my EP3 with over 200 t[…]
