Integra Type R? Come and chat here.
#3731827
PRICES UPDATED JANUARY 2014
Due to loads of repeated PM's I thought it would be easier to list down our popular options on the DC5 Type R suspension & alignment upgrades.
ALIGNMENT
On a standard DC5 the only thing that is actually adjustable is the front & rear wheel alignment (toe). We can also make the front camber adjustable with the use of Eibach adjustable camber bolts - this is essential to get the best handling as the cars usually leave the factory with uneven camber settings usually positive on one side and negative on the other :shock: . This causes very poor handling and steering feel.
The rear camber is also non-adjustable from the factory but again ABP have a way around this :wink: . This is fortunate as most DC5's rear camber leaves a lot to be desired with both sides usually having excessive negative camber causing stepping on the inside edge of the rear tyres. On a standard height car we can usually modify the rear camber arms to get the correct camber but when lowered you will need to use the EIBACH fully adjustable rear camber arms allowing the geometry to be set perfectly. These are essential on lowered DC5's as lowering introduces lots of extra negative camber.
By setting the geometry to fast road spec you will instantly notice improved steering feel, sharper turn-in and reduced under-steer. You will also eliminate uneven tyre wear and the common issue of rear tyres being stepped on the inside edges. Depending on whether you choose to do just the front or both front & rear the improvements improve accordingly.
We offer two options of alignment:
1) ABP Fast Road Set up for STANDARD HEIGHT cars We measure the initial geometry settings and then install fully adjustable front camber bolts in the struts. We modify the original rear camber arms and we then set the front & rear camber and alignment (toe) to our own fast road spec before the car receives its final road test ensuring correct steering wheel position. You will be given a full printed out before & after geometry report.
Front EIBACH adjustable camber bolts £25 inc vat
Labour to check geometry, fit EIBACH bolts, modify rear camber arms and set front AND rear camber & toe to fast road spec £130 inc vat
TOTAL PRICE £155.00 inc vat
2) ABP Fast Road Set up for LOWERED CARS. We measure the initial geometry settings and then install fully adjustable front camber bolts in the struts. We replace the original rear camber arms with new EIBACH fully adjustable arms and we then set the front & rear camber and alignment (toe) to our own fast road spec before the car receives its final road test ensuring correct steering wheel position. You will be given a full printed out before & after geometry report.
Rear EIBACH fully adjustable camber arms £135 inc vat
Labour to check geometry, fit EIBACH bolts, fit adjustable rear EIBACH camber arms, set front and rear camber & toe to fast road spec £130 inc vat
TOTAL PRICE £290 inc vat
SPRINGS & ALIGNMENT
By installing a set of top-quality EIBACH springs you take your DC5 to the next level in the handling department. Far from being harder or crashier the EIBACH's progressive design offers superior handling and improved ride quality / comfort. We commisioned EIBACH to design an exclusive to ABP -30mm front & -35mm rear spring kit which is superb in every way and looks great on the car! This is only for pre-facelift models only but we can supply an Eibach spring set for the later models with -25mm front & -30mm rear lowering with the correct handed springs on the front.
Supply and fit EIBACH -30mm front & -35mm rear lowering spring kit and ABP Fast Road Set up for the front AND rear. We strip down the front and rear suspension removing the original Honda springs and replace them with the new EIBACH lowered spring kit. We then measure the initial geometry settings and then install fully adjustable front camber bolts in the struts. We install fully adjustable EIBACH rear camber arms. We then set the front & rear camber and alignment (toe) to our own fast road spec before the car receives its final road test ensuring correct steering wheel position. You will be given a full printed out before & after geometry report.
ABP / EIBACH -30mm lowering spring kit £150 inc vat
Labour to install lowering spring kit, check geometry, fit EIBACH bolts, fit EIBACH rear arms, set front and rear camber & toe to fast road spec £220 inc vat
TOTAL PRICE £530 inc vat
For the later facelift models the springs are a little more expensive so please add £89 to the total
We are also happy to supply the parts seperately either mail-order, Export or over the counter at our premises in Cheshire.
EIBACH front adjustable cambe bolts £25 pair inc vat
EIBACH rear fully adjustable camber arms £135 inc vat
ABP spec EIBACH -30mm front & 35mm rear lowering spring kits £150 set inc vat (pre facelift models only)
Eibach PRO-KIT (25mm front & 30mm rear) spring kit £239 inc vat (facelift models only)
Pictures of products for you.....
Small stocks :shock:
Springs, camber adjusters and rear arms
Hope this helps and if you need any more info please PM or call me
Dave Roberts [smilie=karls_thumb.gif]
