Post your power charts here.
By k20actr
#3753005
Nice work :salut:
I had the same setup but dc ex. mani,toda A3 cams
and 11.5 compr.from toda head gasket 0.3mm+milling...
274.5cv Rule power at the same dyno and 256cv full stage 1.
If you make and compression the car will grow stronger :wink:
By TIFFOSI
#3753056
In the first setup with these camshafts the engine had an Cosworth compression gasket.
The option to remove it was just for precaution, the gains doesn't pay the possible risk to marry the valve with the piston as the engine is reving 9000 rpm.
I have a 5.46 final drive, it's pulling like a train and I don't even notice the vtec kick.
By k20actr
#3756831
TIFFOSI wrote:In the first setup with these camshafts the engine had an Cosworth compression gasket.
With 9100rpm (no all day all night...rods..) and 0.3mm headgasket + 2tenth mill....i never had any issue valve /pistons...
