Post your power charts here.
By Zen
#3614923
Less than two weeks ago I bought a truely mint 75k miles 2001 JDM ep3 from JM-Imports in Newcastle. The car came with Mugen suspension, Mugen airbox and grill and a Mugen twinloop. Not really chasing power and modifying as I've done it all in the past but had the car setup with a K100 and mapped for the mods it already had when it came into the country.
I'm happy the car seems to be pretty healthy anyway. :-D
#3614945
pulpmelon_r wrote:The JDM motor comes with bigger cams, better inlet manifold and more compression out of the box.
A decent header would finish this off IMO
As well as having different heat ratios and a Jdm LSD
Basically a modded uk ep3 from factory
#3615059
You can't start to imagine just how clean this car is. Its like brand new and full range of quality Mugen parts as well!
We have actually seen really good gains with the standard exhaust manifold after porting it. The welding of the pipes at the flange leaves a really big step so grinding them back to smooth sees it pick up a lot better. :smile:
