Post your power charts here.
By CTRSam
#3594687
Mods?
Very good power for eurospecs dyno
By GMballistic
#3594700
CTRSam wrote: Mods?
"Toda-Buddyclub-gruppeM-Stoptec-k-pro" written in his signature. :salut:
+1 though. :-D Good power and any other mod's not listed? [smilie=karls_thumb.gif]
By motty
#3594718
bluntcap wrote:
motty wrote:No rbc?
he does yea
Was going say
By 6N2 GTI 00
#3597260
Very Decent figures [smilie=karls_thumb.gif]
aaronn wrote:decent my mate only made 231 at eurospec with similar mods
well done
This is a JDM EP3 yo!
By C2AXG
#3600720
Hondata kpro, Toda mani, toda catback, gruppe m, skunk2 70mm tb, 70mm ported rbc.
Jdm engine so different cams and compression?
Maybe could of made more power if vtec came in later but as it is now its more driver friendly
By GMballistic
#3600870
C2AXG wrote:Hondata kpro, Toda mani, toda catback, gruppe m, skunk2 70mm tb, 70mm ported rbc.
Great fun to drive eitherway I'm sure and I'll bet that it goes miles better than it did standard. :wink: :twisted: :-D
By C2AXG
#3601198
You are not wrong!
it is easy to forget how much more power there is and how its delivered, boot it from 1st-2nd gear and it certainly shifts!
The shorter ratio gearbox moves things along nicley too :wink:
What is your Vtec entry point set at Craig?
By jreedy
#3606729
Why would you have made more power if vtec came in later?
The person mapping the car will no when's best to engage vtec surely?
By bluntcap
#3610591
VTEC is set at the optimal point for the mods, most people think if VTEC is earlier they make more power as it is the power cam.
bluntcap wrote:VTEC is set at the optimal point for the mods, most people think if VTEC is earlier they make more power as it is the power cam.
+1 Basically set at the point were the low cam is running out of steam. But bring in the high cam to soon and you will incur a flat spot.
What the mapper should be trying to achieve is a smooth transition between the 2 cams so when the low cam runs out of steam the high one comes in without any jump just smooth power all the way to the redline [smilie=karls_thumb.gif]
By aaronn
#3611261
My mates one mapped by romain is perfectly smooth you hardly feel the kick in vtec now just change in speed
By baddohc
#3611263
Lovely mapper. Don't know he manages some of the figures.
My friends ek9 turbo @ 1.1 bar is 450 bhp and 350 ft lbs of torque.
Originally we thought it may hit around 400/250-280 torque at 20/21 psi (1.5 bar)
