Today was not actually 'fair test' as no back to back was done, but here are the variables that had changed from the last dyno run @ TDi-N:
* Summer not winter, +10 degrees IAT on average per run (23 deg)
* Tesco 99 used, BP 97 used last time
* Less favourable humidity and air pressure
In Pauls experience over years and seasons, the environmental variables between today and the last dyno in January should account for around 7-9hp loss.
Never the less with the 3.5" Short intake we were struggling to get over 260hp (11hp or so down from last time) :bad-words:
In the back of my mind I was worried that this intake design might not be optimal for building velocity and stacking up the resonance correctly. So I took the liberty of bringing a 2.5ft length of spare 3.5" alu pipe with me. We chucked this on so it was sticking up in the air with a v-stack and ran it a few times for the sh*ts.
Boom... 265hp
Neil then chopped the pipe in half to around 18", we ran it and made a similar sort of number. Paul then moved the cam angles and fuelling around a bit and came up with a consistent 267 - 268hp
Running this longer setup in the cold of winter should put me back to where I was before + maybe 1 or 2 extra horse power.
SO what have we learnt?
* Around 28" of intake length works for my motor (similar length to the injen CAI funnily enough)
* An SRI doesn't do you any favours
* The jury is still out on 3" vs 3.5" for a 2L... I think there might only be a few hp in it. :think:
Thanks again to Team TDi.
