- Mon Jul 23, 2012 10:02 am
#3393847
At the current price range it would be rude not to buy a SSD. Some of them now are mega cheap.
Mart wrote:For playing CS only, no. I'm sure I played CS back in the day with a PC spec lower than that. If you intended on playing more modern stuff you would need to upgrade all of it bar the PSU which would be OK for decent budget end gfx cards.Aye I know it wont make a difference for CS. this pc is perfect for CS, loads maps up instantly, 100fps, etc.
SSD's make a massive difference to the load times on absolutely everything from firing up a browser to loading Windows. You would think you had fed your system speed from just the SSD upgrade it does stuff so much faster.
You could get a 4GB or 8GB dual channel set of RAM for dirt cheap, but check first which frequencies your mobo supports.
smartie wrote:Battlefield 3 > 20 year old shooter rehash.That. Played a couple of hours of 1.6 with Wilkeh a while back. I quickly realised 2 things:
m1ke wrote:FUUUUUUUUUUUCCCKKKK.That's well before 1.6
Just found this, it appears somebody made a movie of me from my 1.6 days.
[youtubenew][/youtubenew]
