1. Upgrading your hard drive
You will need:
-a new internal hard drive, 2.5" SATA with an rpm of 5400rpm (7200 does work but offers no benefit in read speed, costs more and causes more heat) 320Gb is the safe maximum as some 500Gbs are too thick to fit the internal chassis.
-an external USB hard drive in FAT32 form. This can be an iPod with hard drive enabled if it was created on a PC. Mac formatted iPods don't work!
-a good quality selection of small Philips screw drivers.
-a kettle, some tea bags and 2 DVDs.
-optionally, a Dremmel (or similar) with a small drill head!
1. Connect your external USB hard drive to one of the USB ports on the front of the machine.
2. In the XMB, go to [System Settings] and then go down to the option that says [Back Up]. This will bring up 3 choices and you want to select [Back Up]. This should then ask you for the destination and show you [USB blah, blah] to select. The back up can take anything from 1-3 hours depending on what you have stored on your PS3. Time to use the kettle, tea bags and sit down and watch that DVD...
3. Once the back up is complete, disconnect your USb hard drive. You might want to save the folder marked [PS3] on your PC or Mac as a second back up in case the restore doesn't work. It won't be a massive file as it's heavily compressed, hence it took so long to transfer.
4. Disconnect your PS3 completely from all the wires, including the power!
5. On one end of the PS3 (the thickest) there's a flap that's easily removed by inserting a thin flat screwdriver or even credit card into the slot and flipping it up.
6. Check your screwdrivers and select the one that fits the blue screw you can see best. You don't want ANY slack in case you chew up the head. Remove that screw. Then flip out the small metal handle and slide the metal chassis to the front of the PS3. It slides about 1cm then you can lift it out completely.
7. Time for care. The original HDD is held in with the 4 small cross headed silver screws you can see on the sides of the chassis. These, from the factory, are held in TIGHT. Undo them with care, using slight pressure into the screw to avoid stripping the head, otherwise you'll need to use a small Dremmel drill to get the screw out!
8. Make sure you note which way round the original HDD is in the chassis, slide it out and put the new HDD in the same way. Then put the screws back in, ideally nowhere near as tight as Sony do! Pop the chassis into the PS3, HDD label side up, and slide it to the back of the console until you can see the hole for the blue screw through the chassis. Put that back in, flatten the handle and pop the cover back on. Easy!
9. Connect and start up the PS3 again. It'll immediately want to format your HDD. Let it do this and then restart when it asks you to.
10. Connect up your USB external HDD and go to the same [Systems Settings] followed by [Back Up] now. Do NOT go to the option that says [Restore PS3 system]! In the menu in the [Back Up] option, it also gives the option to [Restore]. Select that, tell it which device your external HDD is...go and make another cup of tea and watch that second DVD!
You should now have a PS3 that's exactly the same in every way as your original. Nothing gets lost in this process. All your saves, trophies, PSN downloads, music, photos, system settings etc etc will all be intact.
2. Transferring data to a new PS3
You will need:
-an external USB connected hard drive as above
-a pen and paper
Most PS3 failures are due to the BluRay drive failing so the unit is still completely functional bar being unable to read discs. If this is the case, you can retrieve SOME data to transfer. It's worth occasionally backing up the internal HDD just in case you get one of the rarer complete failures. What type of data can you transfer across? Not a lot! Your user accounts will transfer, as will your music, photo and video files, but your system data and preferences won't, nor will Play TV's install (you need to do it again on the new console via the disc) and nor will any of the virtual PS1 and 2 memory cards you've set up or any PSN downloads, whether that's game add ons or stand alone games. As for game saves, most will transfer if you do it the following way, but some games are, strangely, copy protected. So far, I've found this applies to Street Fighter 4, Street Fighter 2 HD and Motorstorm: Pacific Rift, but not the original Motorstorm! None of your installed game data will trasfer either, so get ready to add GT5P and Warhawk all over again...
Right, off we go:
1. follow steps 1 and 2 above to back up your HDD. As I say, very little of the backed up data is usable, but it's still easier to do it this way. MAke sure you back up externally as well. Unlike the 360, you can't plug in an HDD from one console and get it to work straight away. Any new HDD put in your PS3 that it hasn't encountered before will be formatted straight away. You need to back up!
2. Go to [Trophies] and let the synch operation complete itself. Do this for all user accounts. The trophies are held in the PSN account this way and can be retrieved later.
3. Go into each user profile and, next to the name you've used for each one, write down the e-mail address you used for it and the password. The online ID is irrelevant. You can retrieve the e-mail address from the [Account Management] as long as you can remember your password! What you DON'T need to write down is a list of your downloads or saves. It takes ages to that and you don't need to!
4. When you get the new PS3, start it up,connect a controller via USB (remember, it's paired to your old PS3 until then) go through the initial set up instructions and then make sure you create the main accounts and the other user accounts using the same name as the old ones. Go into each one, go to [Sign Into Playstation Network] and select [Existing Account]. You just need to put in the e-mail address and the password, that's all.
5. Once you've done that, now [Restore] your backup as mentioned in step 10 above. You will be informed that not all the data can be backed up and you'll find the restore is suspiciously short lived!
6. Once complete, go into each user account, select [Trophies] and wait for the synch to finish (it takes longer than usual).
7. Go into the Main user account, go to [Account Management] then [Transactions] then [Download History]. From here you can see all your old PSN downloads and can start to download from this menu, rather than hunting them all down on PSN Store. You can only download 16 queued files at a time though. The PS3 you receive should already have Home and the most up to date system pre-installed so that shouldn't be a concern, but remember all those games you bought where an update patch has occured? You're going to have to do ALL those patches again! Good luck! You'll also need to pair up your BD Remote and any other Blutooth accessories you have to the new PS3 as well.
sjw wrote:If I had all the money back that I've wasted on cars, I would waste it on a car.
