First up, an iso image to burn a DVD to help with the first 100 hours of break in. Just leave this running on loop (making sure there are no black bands on the screen) overnight to help with teh first 100 hours of breaking in, which will significantly reduce the chances of image retention and phosphor lag:
http://www.eaprogramming.com/downloads/ ... d_main.htm
If you want to get serious about calibrating the screen, this is the iso to use:
http://www.sendspace.com/file/g9ajmv
More choices here:
http://www.avsforum.com/avs-vb/showthread.php?t=948496
Both gleaned from the excellent AV Science forum:
Also, colour and greyscale calibration for dummies!
http://www.curtpalme.com/forum/viewtopic.php?t=10457
Don't know about Windows, but on a Mac, to burn an iso for htose that don't know, you can do it directly from the included Disc Utility application. Just select the Image menu at the top, slect "Burn..." select the iso you want to burn first, then the DVD burner location second and you're on your way.
sjw wrote:If I had all the money back that I've wasted on cars, I would waste it on a car.
