Pee Zed wrote:My front USB ports are sometimes dodgy, might be just my PC though.smartie wrote:That's not an issue unless you're plugging in your device via some poxy El cheapo external USB hub.Pee Zed wrote:Did you try a different USB slot?Adey wrote:Yes, plus I've rooted a few devices before so I'm not entirely new to the method. However I seem to be one of the unlucky ones who nearly always has issues with devices not being recognised.Pee Zed wrote:Had a crack at whacking on Cyanogen onto my n10 but I had issues with the drivers bit. Seems now W7 can't install the drivers for it, doesn't matter if I have USB debug checked, nor the MFP bit too.Did you use the link Stu gave on the last page? http://www.wugfresh.com/nrt/ I used the driver installation section in that & although I did get a bit lost along the way I did muddle through it. Can't exactly remember where I got lost or what I did to rectify it but I did follow the steps & it all worked out ok. I am using Win 8.1. I then used CWM to flash to Cyanogen.
Anybody else have this issue?
IIRC it is to do with the cable used but I seem to only have one usb cable at the moment...I had 3 before :scratch:
