http://yfrog.com/kjs0ercj
Full spec if you see parts for sale:
SD Cage was new from SD
Spec below
Engine & Gearbox -
- Standard SR20DET
- Recent full exhaust gasket replacement
- Millers Motorsport Oil
- Recent coolant flush
- GREDDY Panel filter
- De Cat
- Braided Turbo Oil & Water lines
- Silkolene Syn Tran 5 Gearbox Fluids
- Good standard gearbox, no crunches or odd noises
- Recent Alternator Overhaul
Suspension & Brakes
- TEIN Super Street Coilovers with cleaned and greased threads (like new)
- Cusco adjustable top mounts
- Caster modification as documented on GTiROC
- Camber adjustment ~ -1.5 front & ~ -1 rear
- Wilwood 310mm 4 Pot BBK fitted with EBC Yellow Pads & Braided Hoses
- EBC Yellow pads rear
- Motul RBF600 Brake Fluid
Interior & Safety
- Safety Devices 6 point FIA Roll Cage & Harness Bar
- Willians 3" 6 Point Harnesses - Key point is the buckle is fitted to lap strap
- Cobra Imola 2 Bucket Seats
- OMP Dished Suede Steering Wheel
- Boost gauge
- Lightened interior wiring harness, sheafed, etc
- Re-located Battery
- Re-located Windscreen Washer Bottle
- JDM Flare (Just in case)
- Floor sprayed satin black to make it look neater
- Sound deadening removed
- Pax foot rest
Wheels & Tyres
- 16" Team Dynamics 2 & as new Falken road tyres
