Glad everyone is ok.
Hope it sorted with little hassle. :salut:
power is nothin without control!!
JDM ネツアイ
COSMIC T.C wrote:So sorry to hear malakie. No more fn2 pics at jae now.I hope he gets a new car by then. He makes me laugh too much not to turn up.
Sedge probably joined the party, and there endeth the party.
Mark83 wrote:Must have been even worse seeing it on CCTVLike being raped.
J wrote:This.COSMIC T.C wrote:So sorry to hear malakie. No more fn2 pics at jae now.I hope he gets a new car by then. He makes me laugh too much not to turn up.
Malakie wrote:ANYONE KNOW WHERE THE ENGINE NUMBER IS ON THE K20 ENGINE AS ONE HAS COME UP FOR SALE IN MY LOCAL AREA AND I WANT TO GO AND CHECK IT OUT!!!!!Just looked in my manual and on the ep3 it looks to be to the right hand side of the i-vtec cover :thumbup:
tonyb86 wrote:i know you have an fn2 but would have though it would be the same place .Malakie wrote:ANYONE KNOW WHERE THE ENGINE NUMBER IS ON THE K20 ENGINE AS ONE HAS COME UP FOR SALE IN MY LOCAL AREA AND I WANT TO GO AND CHECK IT OUT!!!!!Just looked in my manual and on the ep3 it looks to be to the right hand side of the i-vtec cover :thumbup:
Malakie wrote:ANYONE KNOW WHERE THE ENGINE NUMBER IS ON THE K20 ENGINE AS ONE HAS COME UP FOR SALE IN MY LOCAL AREA AND I WANT TO GO AND CHECK IT OUT!!!!!Deffinately go check it out mate!!!
There's a sticker I believe on the timing chain cover. On it, it should say something like:
2PRC-0A01E 267 1
K20A-3604483
OR
2PRB-AA000 270 1
K20A2-14022221
PRB = Type-S ECU
PRC= Type-R ECU
PNF = Base ECU
The VIN is located at the back of the engine, underneath the halfshaft. There should also be one on the transmission which should match if you bought a complete swap from the same car.Is that like a number stamped on back of engine, on left, next to where the manifold should be bolted. Above blue bolt to the left.??
a2 cams are 3 lobe. you can also look at the sticker on the timing chain cover. but looking at the cams and block stamp are you're best bet. ecu, intake manifold, trans, etc can all be switched
They stamp the block by the starter under the intake manifold. The intake manifolds for the base are completely different than on the type-SAbove info was collected from k20.org, club rsx and honda tech. hope it helps.
