Thanks in advance
Lewisgame wrote:Needs rubbing down first to see what the real damage is. The second picture, the big spot looks pretty bad. It'll probably need cutting out and a new plate welded in place. The others could probably be treated and painted. Easiest option is to apply rust treatment to stop it spreading and put a normal sized number plate back on to cover it. Or find a good second hand tailgate that someone hasn't drilled into.Thanks for the reply Lewis, my mate who owns a body shop is going to sort it for me which will be cheaper than buying a new a tailgate as myste does it all at cost for me
mjhamilton wrote:Love the way some spanner monkey drilled the metal to fit the plate when there are already visible nylon captive nuts already there ready for the jobI know I thought the exact same thing! Can't believe they drilled the metal when they are already the captive nuts there to use :scratch:
tomhighton wrote:Carbon bootlid![]()
Lewisgame wrote:Chances are the plastic screws snapped off inside the captive nut. Instead of drilling the plastic out, they just went trigger happy in the tailgate. They could of just used double sided tapeThat's what I have always used mammoth double sided tape & that won't ever come off
